Results 1 to 23 of 23
    Jan 05 2015
    London
    Disconnect MAF impact on LTFT and other warning lights?
    Disconnected my MAF and ran the car for a short while and noticed the following:
    - TMPS warning came on
    - ESP/ESC light came on
    - in MAF reading was around 363g/s
    - the on throttle (i.e. mult) LTFT rose from c.10% to c.18%
    Is this all normal behavior?
    Don't suppose anyone would be able to do the same and check the MAF reading and LTFT impact of driving for 30 mins with the MAF disconnected?
    Cheers
    Senior Member Three Rings Van Black's Avatar
    Sep 07 2015
    Romania
    May I ask why you chose to do this?
    Account Terminated Two Rings
    Sep 28 2014
    your moms
    Esp light is normal. Did u do this to boost more? Lol
    Jun 27 2011
    WHen you unplug the MAF your ECU goes into default mode or whatever you want to call it and the dash generally lights up like a christmas tree.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jan 05 2015
    London
    Quote Originally Posted by Van Black View Post
    I was trying to chase down a slightly high throttle mult ltft, person I want to remap suggested I try this (also changed maf, o2 sensor, hp sensor, fuel filter, n80 recently, no leak in TIP and the idle/adap ltft is spot on). Car actually boosts fine but before start putting extra load on car, I wanted to see if I could get everything nicely in spec.
    Jan 05 2015
    London
    Ah ok, I thought the lights on might be normal.
    Anyone able to add their own observations on the LTFT - or even better anyone willing to try this and add their findings?
    Sep 07 2015
    Romania
    Quote Originally Posted by MrBigglesworth View Post
    You can reset the throttle body adaptation, if that's what you're looking into. Can't help with VAGCOM info since I don't have one, but Charles is right, when you unplug a sensor the ECU goes into failure mode and automatically sets a default value for said sensor, so unplugging the MAF won't do much. I think you're better of recording what all the sensors read during normal drive and check against target values.
    Jan 05 2015
    London
    Done throttle body adaptation and logging during normal driving. Just looking for a refernce point for the ltft change when MAF disconnected.
    Sep 07 2015
    Romania
    Could you explain what you mean by LTFT? I don't know this abbreviation
    Dec 23 2011
    Long term fuel trim
    Sep 07 2015
    Romania
    Okay then, 10% on the LTFT seems a bit high...I've been looking into this and apparently the ECU doesn't shoot an error until it reaches 25% +/-.
    Also, the tech say it should be around 0% -> +/- 3%.
    Did you check your O2 sensors? Also check for leaks on the intake side, PCV valve and intercoolers. A small leak could cause the system to read
    too lean and add fuel to compensate.
    Jan 05 2015
    London
    You are right, it is slightly out of spec, nothing catastrophic, but that's why I am trying to see if it can be rectified.
    Mentioned earlier that I've changed the O2 sensor and tested the turbo intake pipe alreadyfor leaks. Way I see it, leak after the turbo would cause a boost leak and it would run rich not lean.
    Forgot to mention that PCV was also changed last year, and rocker cover gasket too.
    I'm curious about the result I got on disconnecting the MAF. I expected it to not really change or actually go rich as I had read that the default ecu maps were meant to run slightly rich for safety. It getting more lean made me wonder if something else is still inputting and that causes it go leaner. Not sure what this. From some reading today I am wondering if the MAP sensor could be doing it?
    Jun 27 2011
    Why would you care about the LTFT while the MAF is unplugged though?
    -CP
    2017 Q7 3.0t
    Jan 05 2015
    London
    I just thought it was a strange result and may give me some useful information about the underlying issue - which is why I was hoping I could get a reference from someone else who has done this/can do this to see if it is actually normal or not.
    Sep 07 2015
    Romania
    I've got a shot intercooler and the error I get it AFR too lean at idle. It doesn't seem to affect the load too much. It's worth
    giving it a look, rocks tend to fly in the air intake for the IC.
    Jan 05 2015
    London
    Thanks, but the way I see it is that if you had an intercooler with some kind of leak then it would suck in air under vacuum (hence lean at idle), but it would be losing air when under boost (or rich under throttle) . I have very in spec idle performance (LTFT is 0% +/- 1%), but lean on throttle performance - so the symptoms don't match your cause - although I may not be understanding everything correctly!
    Sep 07 2015
    Romania
    You're right, in you're case it looks more like a fuel system problem, like injectors not closing properly or fast enough.
    I doubt the HPFP or regulator valve could cause this, I believe the ECU would be able to trim a too high pressure in the rail.
    Jan 05 2015
    London
    Yeah - injectors are on my watch list - need to get them scoped or something!
    Sep 07 2015
    Romania
    Can't think of anything else.
    Maybe keep us posted on the progress.
    Best of luck!
    Established Member Two Rings p310b's Avatar
    Jan 15 2016
    Indonesia
    Cheers
    So if I might be able to help you, I will just pop off my MAF sensor then log while drive it for 30mins? May I know under which block do you want me to log it for you?
    Jan 05 2015
    London
    Quote Originally Posted by p310b View Post
    That would be great and yes - its basically popping the lead off the MAF sensor and then driving for 20-30 mins (normal/slightly easier than normal driving I would say) and seeing what block 32 measuring block values were before and after you did this.
    Also is you 2.0T stock? With the MAF connected as normal, can you please let me know what you get on block 2 measuring block values for the MAF (in g/s) under a wide open throttle run (peak value doing a saved data log).
    Cheers
    Jan 15 2016
    Indonesia
    Cheers
    Hi, i did the log, do you have email for me to send?
    Jan 05 2015
    London
    I've messaged you. Big thanks!
