Results 1 to 9 of 9
    Senior Member Two Rings krewbrew's Avatar
    Apr 26 2014
    2013 Touareg V6
    Westchester County NY
    unidentifiable squeak is making me crazy
    I have been trying to figure out a clunking/squeaking noise for several months. The noise has been getting worse, and has now changed mostly to a squeak.
    Check it out here: https://youtu.be/OSM9ZJleN-A
    It generally sounds like it is coming from the front left 75% of the time and right rear 25% of the time. The noise does not happen under acceleration or deceleration. It seems to happen at lower speeds when turning or when weight is shifting while going straight. It happens both in gear and out of gear. It happens with the brakes applied or not applied. It is somewhat infrequent and hard to place. Sometimes it sounds like it is coming from below the shifter. I do not feel it in the steering wheel or shifter. It can't be duplicated when rocking the car. It seemed yesterday that it did not happen at all when the car was cold (25 degree weather). It started after I had driven it for a while. I posted the other day about local audi mechanics in Westchester County NY and did not get any rave reviews. I took it to a well respected general mechanic who was unable to identify the source. He greased various suspension components, after which the clunk seems to have subsided and the squeaking gotten worse. Need to drive it some more to see if that holds true.
    I have replaced motor mounts, snub mount, transmission mount, and brakes. I have inspected and checked tightness of the front and rear sway bars and front subframe. I have raised the front wheels and tried the move the tires at 3 and 9 o’clock to see if there are control arm issues. Front control arms all look good. I have checked the driveshaft bearing. The driveshaft was found to be damaged and I had it replaced with a used one. I also checked the tightness of the two power steering rack bolts under the battery and by the brake fluid container.
    Next step might be front sway bar bushings, but I am getting tired of throwing parts at this and would like some ideas.
    Any suggestions on how to diagnose this would be greatly appreciated.
    Kevin
    2015 A7
    Dec 06 2012
    Tacoma WA
    I'm no expert but it sounds like it could be a bad shock. See if you can make the noise by pushing down on the fender of your car a couple times to see if you can reproduce the issue.
    Apr 26 2014
    2013 Touareg V6
    Thanks. Can't duplicate the noise by rocking the car. All sounds fine.
    Kevin
    2015 A7
    Feb 05 2011
    A3 (sold), 2x B5 a4 avant (sold), b6 avant (sold), b7 avant (sold), b8 S4 avant swap. RS4 avant swap
    phila/PA/Northeast
    I had a bad wheel hub make squeaking noises
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Jiggle the exhaust with your foot and see if you hear it
    Apr 26 2014
    2013 Touareg V6
    Thanks for the replies.
    Quote Originally Posted by audiphila View Post
    I don't hear any bearing type noise and the wheels doesn't move abnormally. Anything else to check?
    Quote Originally Posted by Sanjman View Post
    All quiet on the exhaust.
    Kevin
    2015 A7
    Veteran Member Three Rings Ray1031's Avatar
    Nov 01 2015
    San Antonio, TX
    Check this out, http://humblemechanic.com/2015/04/15...gs-fail-video/
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    bearing and the flowing air in your phone.
    Apr 26 2014
    2013 Touareg V6
    OK I will look to get the wheel bearing replaced. Can I be sure that it is left front since that is where I hear most of the noise?
    Kevin
    2015 A7
