Results 1 to 8 of 8
    Aug 25 2004
    audi
    Replacing motor in 06 2.0t quattro automatic with an engine from an 09 cab cvt.. help
    Hi Guys
    my motor is toast
    i found a 2.0 from a 2009 b7 a4 cabriolet CVT. will the motor be a direct swap ? thanks
    AKA: djwaffelz
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Im not 100% but I think thats a TFSI engine and I dont think they are compatable.
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Aug 25 2004
    audi
    the engine is the same old model 2.0
    AKA: djwaffelz
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by kgny1 View Post
    Hi Guys
    my motor is toast
    Assuming the engine is a BWT, then yes it should be a direct swap.
    -Adam
    Jun 27 2011
    Yup should be the same. The b7 cab ran until 2009.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 25 2004
    audi
    thanks so much Guys !!
    AKA: djwaffelz
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    I thought I read in this forum that the pilot bearing area is different between auto and CVT/Manual.
    Maybe you can go CVT/Manual/Auto crank to Auto trans?
    But not Auto crank to CVT/Manual trans?
    Someone with direct knowledge should chime in.
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Older_not_Wiser View Post
    The manual/cvt crank will work fine in a tiptronic car, but a tiptronic crank will not work in a manual/cvt car. I'm not entirely sure a flywheel would fit on a tip crank.
    Tiptronic crank:
    Manual/CVT crank:
    Notice the different shape on the end of the crank. Which style do you have?
    -Adam
