    Mar 01 2006
    Kitchener, ON
    EGR valve maintenance
    So curious if anyone had performed any maintenance on them before?
    https://www.ecstuning.com/Audi-B8_S4...ne/Emissions/2
    Issue is I got p0491 / p0492 codes that popped up. I know before you say 'carbon build up'...there are some interesting symptoms...
    So the code came up last winter, and I cleared them. It got warm, and the code never came back. Sweet, false alarm...this winter comes and suddenly drops below 0 and the code comes back. It warmed up on the weekend and the code disappeared...where Monday morning it dropped and the code came back.
    Took it to the mechanic, and he agreed, doesn't sound like carbon build-up or it would have stayed on due to restrictions.
    It turns out he said the EGR valves or combi valves are stuck and not opening wide enough so he wanted to replace them. The first thing not covered by my aftermarket warranty go figure...the pump does seem to be running fine though.
    Any ideas? Unfortunately, not a whole of them floating around the wreckers, and it sounds like due to labor you might as well just put new ones in
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    Quote Originally Posted by RudyH View Post
    These cars can be funky in the cold. My ADS module would randomly stop working last winter on the really cold days. But Once I cleaned my garage and park in there it has never happened again.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Mar 01 2006
    Kitchener, ON
    Just adding this ... been using One Note too much ... for reference for everyone when they need to start troubleshooting and need cheapest pricing
    https://www.carpartsdiscount.com/cat...html?3594=2184
    Past
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Umm last time I checked the engine doesn't have EGR anymore. Its all done with adjustable valve timing now. Those are your SAI (secondary air injection valves) Entirely different than EGR. All the SAI is for is to help bring the converters up to temp faster.
    A flow problem since your getting it on both banks, My guess is from most likely to least likely, The pump is having issues or the valves are not opening correctly. Its a flow problem. So like your mechanic said your valves could be sticking and not opening correctly or your pump is weak when its cold out. Those systems sux to diag when you have flow codes.
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by chaos2984 View Post
    I think it's the same valve we are both referring to...EGR valve or combi valve - they are listed parts for our cars
    The mechanic said he can see flow, but can't tell how much since the valves aren't opening up all the way so he said he would try that first before going after the pump
    I thought *maybe* you could throw something at it to make the sticky valves work again, but sounds like with all the work involved it's easier to replace. $200 parts but a lot of work to get to them
    Getting also an O2 sensor fault, which I forgot to confirm this morning but was in historical so I didn't notice it before. Seems generally these are tied together.
    Past
