Results 1 to 6 of 6
    Jul 26 2015
    MT
    Need Help With B8.5 Headlight Disassembly
    I am needing help with disassembling my headlights. I reached out to a couple different shops to do the work but they either don't want to work on S4 headlights or I haven't got a response back from them. So I have decided to disassemble them and replace the projector lens with a clear lens among a few other mods to them. What I am wondering is if someone can tell me the best way to remove the outer lens from the headlight. Baking method? If so for how long and what temp. Or do I just go with the heat gun method? Also do I need to remove the led strips to get to the projector lens?
    ~2013 S4 - Moonlight Blue~
    Jul 13 2015
    Central PA
    I did the same thing last year: http://www.audizine.com/forum/showth...-Blackout-Look
    best method for me was heat gun. you need to take everything apart to get to lens. That includes all LED strips and plastic.
    Oct 20 2008
    Denver
    1) Heat gun or bake at 250F for 10 minutes. You only need the sealant to loosen up a bit in order to separate the lense cover.
    2) From what I remember you don't need to touch the led strip to get to the projector, but then again I've never needed to swap the projectors. Good luck!
    Oct 14 2012
    Empty...for now...
    SE PA
    I've done it a few times and had success using a heat gun. I had it on high heat, about 2 inches away from the sealed joint, and moved at a steady pace making sure not to stop and concentrate on any one spot (because it causes the plastic housing to crinkle/melt). After a few passes all the way around, I used a plastic interior trim removal tool (http://www.harborfreight.com/5-piece...set-67021.html) (the one in the middle of the linked photo) to gently pry the cover from the housing. I would stick the end of the tool into the joint and twist it a little to push the cover off the housing. If it fights you too much, do another pass with the heat gun and try again.
    Oh, and remove all of the black metal clips before doing any of this. If possible, slide the clip off as opposed to prying it. On a couple of them, a piece of the plastic on the housing where the clip grabs actually broke off under the force of the clip being pried off. Whoops!
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    ive done many with a heat gun, helps if its done on a warm day, but those are hard to come by this time of year.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Feb 20 2006
    NC
    Do you reuse the existing sealant or did you need new sealant in addition? If so, what do you use? Never baked a light before.
    Thanking of going to clear lenses, does it really make a difference?
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
