Results 1 to 13 of 13
    Dec 02 2009
    M3
    Dubai
    RS4 Diff grinding noise..........Help
    My 2001 RS4 has this grinding noise while driving. Seemed to come from the bottom.
    Current mileage is 160,000 KM. Engine is healthy. Two new OE spec Turbo installed about 10,000 km ago. Gear changes were smooth.
    Opened up the diff & saw these small metal shavings.
    Dec 02 2009
    M3
    Dubai
    Ok some update pics .
    Been told by the garage that the diff is bust. But the top silver gear on the diff. looks as good as new.
    Notice the wear on the ring pinion?
    Any observations, suggestions?
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    It's toast. You'll want to open it up and see if any bearings failed, especially the pinion thrust.
    2005 A4 Avant 1.8t QTM
    Dec 02 2009
    M3
    Dubai
    Open the diff or the gearbox?
    Aug 06 2008
    Canadia
    Hard to say without better pics of the ring and pinion. Wear on the ring gear looked ok, but looks like a chunk is Missing off the pinion?
    Given your climate I would probably be running some fairly thick gear oil in there, maybe even a single weight gear oil since your temperatures stay fairly consistent year round. I'm willing to bet lack of maintenance/too thin an oil is the culprit or a very contributing factor. These diffs aren't known to fail.
    the B5 S4 is like the mafia... there is only one way out!
    Dec 02 2009
    M3
    Dubai
    Some close up of the open diff housing.
    The gearbox is yet to be opened.
    Have a look here the gears ,diff. Can someone spot anything that's broken, worn out more than normal?
    May 16 2008
    South Texas
    It's not entirely uncommon to see ring and pinion failure on the 01E transmissions with the pump. This is because the oil lines leak and nobody ever checks or changes the trans fluid level. You will need a complete teardown to clean all the debris out of the gearbox and probably have to replace the synchros as metal fragments tend to embed themselves in the rings. Of course you will need to replace the ring and pinion, and possibly the pinion bearing as those parts are the first to go when oil starvation is an issue. I've seen this on a number of Allroads as well as the diesel gearboxes with the pump. Hit me up if you want a custom gearbox build.
    Dec 02 2009
    M3
    Dubai
    Thanks Scott.
    Yes I would be interested in a rebuild trans & gearbox with new bits like pinion & drown gear, bearings , seals, new synchros installed.
    Please PM me the related costs & shipping to Dubai at your earliest.
    Cheers
    Sam
    Senior Member Two Rings Lanorg's Avatar
    Apr 22 2013
    Floor jacks, torque wrenches, and winter tires
    Was the grinding noise apparent when rolling in a straight line vs turning? Or on throttle straight vs a corner?
    I have a noise that develops when cornering only with my BBS 18" CH wheels but not my SSR 17"
    Dec 02 2009
    M3
    Dubai
    It was a running noise. I could feel how smooth the engine was. But this defo was a gearbox/diff type of a grinding noise from bottom.
    Dec 02 2009
    M3
    Dubai
    Hey Scott....waiting for your quote.
    Thanks
    Dec 02 2009
    M3
    Dubai
    Scott
    Pls send me your quote.
    Aug 04 2013
    Pennsylvania
    You could contact him. He lists his number in his signature, and I'm sure his email is on his site...
    I'm like a tree. I'm all root
