I wanted to get a thread going tracking my progress at restoring or hopefully getting back to pristine condition on a light silver metallic 2003 Audi S6. Nothing crazy compared to some of the other builds on here (at least not yet). This thread will mainly focus on maintenance BS for the most part then possibly some other ideas I may pursue. I'm going to try and document all the struggles and success' more or less for my own records. So please follow and comment if you would like. This first post is epic long so I do apologize (and it really is my first post, new to AZ but have always visited to check out some build threads). I took a lot of pics just messing around and have compiled everything in the next few posts. This thread wasn't meant as a DIY walkthrough as there are many available resources here and online elsewhere, just a log to record everything to get to the goal of building the dream car.
I purchased an S6 in Oct of '15 w/ 153k on the clock. The previous owner kind of let the car go but he was the 3rd owner and couldn't keep up w/ maintenance and costs. So for me I picked her up for 5k! What a steal. I've had VW's ever since I could drive and know my way around this chassis due to my '04 VW Passat 5sp wagon. The C5 and B5.5 have almost identical chassis components which makes working on it a breeze for me. The car itself runs great but is suffering from a little coolant loss. The PO thought it was the infamous oil cooler pipe but I tracked some leakage to bad seals on the long coolant pipe on the back of the engine. The suspension was clunking on full lock, the headliner was torn in 3 spots (due to the PO moving some shit and tearing it but it's really not that bad), little interior bits here and there were showing age, the OEM wheels were replaced w/ some cheapo knock off faux piece mesh wheels, but overall nothing major. Scanned w/ VagCom and everything was fine. Only DTC was for a faulty driver's and passenger door actuator, headlight level sensor, and some intermittent HVAC actuator. The tranny is strong and isn't showing any signs of sluggishness. So here she is a few days after I picked her up.
I drove her around for a few weeks then decided to tear into it. The PO had no record of the timing belt being replaced so I figured it was a time bomb waiting to happen. I've done the TB on my other cars and bought most of the tools needed. Opted for the ECS Ultimate Kit and attempted a TB job but the weather here got cold, freezing cold. Project went on hold.
She sat like this for over a month through Thanksgiving. Great for insurance! Got a refund back by putting her into comprehensive coverage only.
While waiting for the cold weather to warm up, I decided to work on other things. Replaced a lot of interior pieces. Passenger rear HVAC controls were kicked in by the PO's kids and was replaced. Put in OEM rubber weather mats. Fixed the cowling that was leaking through the pollen filter. Replaced pollen filter. Replaced center console arm rest cover. Bought a new key fob and drilled out the immobilizer chip to transfer to new key, switched in the key blade to new fob. Bought new HVAC control unit as the original buttons were worn down. Tore into the HVAC fan under the glove box due to squeeky fan. Cleaned the fan assembly and re-lubed, smooth as buttah. Replaced all interior and rear license plate bulbs w/ LEDS. Replaced the door actuator. This video came in real handy
Then went a little parts crazy. Compiled a list of everything that needed replacing or fixing. During the TB job attempt noticed both, yes BOTH front inner CV joints destroyed, the outers were fine (that's a first ). CV axles were not OEM so decided to go w/ Autozone remans but the local Autozone rep was a complete jackwad on the phone and sounded like he really hated his job. Well decided to never deal w/ them ever again. Plan B purchased some OP Parts remans. Then had to deal w/ an incompetant parts supplier that shipped 2 axles w/ different inner flange design.
The OEM CV's have a tri-pod inner joint w/ slits in the bolt pattern. I would assume Audi engineers chose this design for a reason. Maybe the slits offer a little bit of give and flex w/ the amount of torque produced by the BBD? Sent a few emails back and forth w/ the parts supplier and they claim the universal style CV joint is an "updated" design and it will be just fine. But then he tells me the passenger CV they sent is the incorrect one, they sent me an allroad axle not S6 . They offering to replace it when I ship it back or to buy another and they'll send a free return label. I opted to just buy another and get the label. I get the replacement passenger CV and notice it has the correct tri-pod design inner shaft w/ the slits in the flange. WTF?
Nice packaging by the way on the replacment .
I'm getting frustrated at this point, I have one universal type inner CV joint and now a tri-pod inner joint. Exchange a few emails and he assures me that either design will fit fine. I do a couple searches around and it seems as long it bolts up and has the correct length it really shouldn't be an issue. I really don't have anything else to tell the parts supplier at this point because it's 29* outside and I'm not going to try and attempt to even touch the car to see if these all fit properly.
Since it's so cold outside I focus on other things to do. Pull the headlights and do a full restoration w/ clear corner mod.
Put in brand new butyl glue to button it up. Installed some new Osram Xenarc D2S bulbs along w/ chrome signals now that it was cleared out. Still needs another polish before I UV coat it w/ some spar urethane.
Before vs. After
Decided I didn't like the tail lights w/ the amber. Got a little present from Deutschland.
OEM C5 4B facelift tails off of an RS6 Avant.
Much better! Those Germans sure do know how to pack a package. These things were wrapped w/ so much bubble wrap it could of survived a hurricane.
By now it was already December and almost Xmas. The weather was getting worse and I was getting bored and started to do more research, more holiday sales, more parts: picked up an ECS BBK w/ 6 pot brembos for a steal (still waiting, expected shipping mid Jan). Bought Apikol rear caliper brackets to run D3 A8 310x22mm rotors on stock pads/calipers. Should be able to get the bigger rotor but only utilize about 80% of the surface for braking. It will be an improvement in terms of heat disapation and cooling. Stock pads which will be upgraded to Hawk HPS along w/ the front BBK should help. I know a lot of guys have had trouble running the rear kits from 034 and JHM but it seems Apikol has developed a 4.2/S6 specific bracket that is plug and play. Time will tell once I install it. I know LazerfaceRictus has reached out to me on my IG to get feedback but I haven't got the chance to install them yet.
By the way D3 A8 310x22mm rear rotors = dirt cheap. Picked up these Brembos from AutohausAZ $120 w/ free shipping . These things are massive
Picked up a set of ST Coils on the cheapo as well for sub $700. I just couldn't let all these deals pass me by! I was really considering going air but because I need my trunk space (road trips, golfing w/ my buddies, HomeDepot runs etc) decided to stick w/ coils. I'm running Bilstein PSS9's on the Passat and love them but couldn't justify the price tag again for the S6.
If I'm going low then well sh*t might as well find new wheels. After a couple days looking at some rebuilt 3 piece wheels I came up on an offer too good to pass up on Miro's. A company in CA was having an Xmas sale buy 3 get the 4th free. I was eyeing the Miro 110's but unfortunately they don't offer them in 19" in a 5X112. I reached to out FM Wheels who do re-drilling and they offered to price match the competitor. Can't tell you how easy it was to work w/ Abe at FM Wheels. He got me hooked up on a re-drill and matched the price for me for sub $900. Decided on Miro 110's 19x8.5 and 19x10, offset's will be dialed in later. Abe posted a teaser on his IG feed of my wheels being completed:
Then they showed up after Xmas!
Very clean work there.
Wiiiiide and concave
While waiting for better weather, decided to fix an AC condenser sensor I broke during the TB job attempt. The clip no longer would stay on since the clip cracked off.
I found an OEM clip on Ebay and it came w/ everything you needed, including connectors, rubber weather gasket, and clip to hold all the wiring in.
Started off by clipping the wires then stripping them. Used the supplied connectors to pinch the wires in.
Then seated them into the switch, making note of where each color goes.
Make sure to clip the connectors in so that they will connect to the pins on the AC condesner side
Snap retaining clip to hold the wiring in and all done.
