Results 1 to 7 of 7
    Sep 24 2013
    Chicago, IL
    Has anyone mounted a none 5x112 bolt pattern wheel on an a4 b8?
    Just looking to see if I can mount a different bolt pattern wheel on my a4 b8. Any help is appreciated
    Established Member Two Rings darkstarghost's Avatar
    Feb 08 2014
    2014 Estoril blue s4
    uhhhh, not without a adapter, rebore, or wabble bolts if you have the balls.
    Sep 24 2013
    Chicago, IL
    Why do u need balls for wabble bolts?
    Aug 15 2014
    The main issue with our B8s is that we can't run low offsets without some fender work. That being said, most people opt out since adapters usually require 20mm thickness and would cause the wheels to poke out too far.
    Your other option is to run wobble bolts, but that limits you to 5x114 bolt patterns. Tons of VW guys run wobble bolts without any issues.
    This beautiful B8 is on wobble bolts here.
    For Sale: Mini Part Out
    Sep 24 2013
    Chicago, IL
    Thanks fellas I'll do more research on the wabble bolts
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    omfg for a sec thought my 5x112 wouldn't fit.
    Established Member Two Rings 99r6's Avatar
    Dec 03 2015
    Wichita
    I didn't know wobble bolts existed until today
    2011 A4 B8, 1985 E30 (M50 Turbo), 2002 Ram 1500 (Lifted + 35"s), 2015 Grom
