Page 2 of 15 FirstFirst 123412 ... LastLast
Results 41 to 80 of 591
  1. #41
    Feb 16 2016
    Belgium
    still waiting om some descent coilovers before i purchase a new set of wheels....,like most people i guess :(
  2. #42
    Veteran Member Four Rings b4a41point8t's Avatar
    Jun 06 2009
    Los Angeles, CA
    Quote Originally Posted by Cyrax View Post
    Yeah, seems to be the likely cause. At this point, id even take springs (quattro).
  3. #43
    Aug 09 2016
    New York
    H&R came out with Springs and Street Coilovers.
    Who is the offset guru here? I'd like to run 19x10 all around w/ at minimum 255 width tires on a 35 sidewall (255/35/19). What's the offset I should be looking at?
    Looking to lower on coils and the lowest I'll go would be just no wheel gap.
    I had an Infiniti prior to the B9 A4, so I'm not that familiar with Audi fitment. In my Infiniti I ran 20x10 et 40 rear and 20x9 et 35 front with tires 275/30 and 245/35
  4. #44
    Veteran Member Three Rings Nikoman's Avatar
    Feb 04 2008
    2015 Jeep Grand Cherokee
    Chicago, IL
    255/35/19 is a very popular and good choice. It's slightly larger diameter on most tire brands than OEM tire sizes. I've also had two G coupes and several Audis over the years with aftermarket wheels on all of them.
    Here are some wheel + tire fitments I'd recommend for a "flush" look.
    19x9 32ET + 255/35/19 tires
    19x9.5 35ET + 255/35/19 tires
    19x8.5 35ET will look closer to OEM like most of the eBay wheels on page 1 of this thread. In between OEM offset and flush with fender. It's commonly selected since many lower priced wheels brands only offer 8.5 wide and 35 offset. When you jump to 10 wide, you may get that wider wheel than tire look with 255s. Plus, wheels and tires can get significantly heavier at those larger sizes. I don't like spacers so I always choose wheel brands that offer the offset I want and work with 255s; and I try to keep the overall weights less than OEM because going fast matters.
    2017 A4 Premium Plus Mythos Black + Sport + Cold Weather
  5. #45
    Jun 06 2009
    Los Angeles, CA
    I'm about 30 mins from pulling the trigger on ground force gf6, deep concave wheels, 19x9.5, et 35, with the 255 tire. My only concern is stretch, but it looks to be pretty square. Anyone have first hand experience with these sizes?
  6. #46
    Feb 04 2008
    Chicago, IL
    You'll be pretty square with that fitment, regardless of the wheels brand.
  7. #47
    Aug 09 2016
    New York
    What would the offset be for 19x10 flush look with 255 tires...40?
    The setup would be on coils and "no wheel gap" drop
  8. #48
    Feb 04 2008
    Chicago, IL
    you'll have a slight stretched look. The B8 and 8.5 posts will look similar since the B9 is a similar chassis.
  9. #49
    Established Member Two Rings ekyp's Avatar
    Aug 24 2012
    Vancouver, BC
    Nothing fancy, bought a set of new 18" replika wheels for my winter setup
    Miss my OEM 19" already, but these will do till winters over. Haha
    Sent from my SM-G935W8 using Tapatalk
    2017 Audi A4 S-Line | Mythos Black, 2019 Audi S4 | Mythos Black, 2021 Audi SQ5 Sportback | Mythos Black
  10. #50
    Veteran Member Three Rings bengtc's Avatar
    Mar 13 2009
    2012 S4
    Dallas
    Wheel Manufacturer: Avant Garde
    Wheel Diameter x Width: 19x8.5
    Wheel Offset: 40
    Finish: antique bronze
    Tire Size: 255/35/19
    Suspension: stock sports
    2012 S4 black, prestige, titanium, sport diff
    ** stasis tune ** kw street comfort coilovers ** vmr v701 19x9.5 midnight blue ** awe res exhaust res dp's quad black diamond tips ** injen intake **
    ** alu kreuz ** hotchkis front and rear sways ** spc adj control arms ** 034 end links ** akebono ceramic pads ** ecs slotted/drilled rotors
    ** rs4 grille ** blesk led plate bulbs ** hoen yellow fogs ** drive tech interior LEDs **
  11. #51
    Feb 16 2016
    Belgium
    looks good,planning on lowering the car ?
  12. #52
    Feb 04 2008
    Chicago, IL
    Quote Originally Posted by ekyp View Post
    Looks good. What tire size did you get? Looks like you went slightly wider and taller sidewall from here.
    I'm thinking of switching out my OEM all seasons for winter tires. This winter has started out rough.
  13. #53
    Aug 24 2012
    Vancouver, BC
    Quote Originally Posted by Nikoman View Post
    Hey, these are actually just the 245/40/18 Michelin X-ice 3. The wheels have 35 offset so maybe it looks wider?
    I believe these are the same size as the stock 18.
  14. #54
    Veteran Member Three Rings casuso's Avatar
    Sep 19 2006
    Mexico
    Quote Originally Posted by bengtc View Post
    Wheel Offset: 40
    Any front or rear pictures to see how that width/offset looks?
    A4 B9 Tango Red Sline FWD
  15. #55
    Mar 13 2009
    2012 S4
    Dallas
    Quote Originally Posted by casuso View Post
    Don't have any right now, but the width and offset are the same as the stock sport 19 inch wheels
  16. #56
    Feb 04 2008
    Chicago, IL
    All these wheel setups look great. Well done all. I can't wait until winter is over...
  17. #57
    Feb 04 2008
    Chicago, IL
    They look like 35 offset. Just saying...
  18. #58
    Mar 26 2016
    My setup
    19x8.5, 35mm offset, tires 255/35/19
    [IMG][/IMG]
  19. #59
    Registered User Four Rings EmmanueleDesign's Avatar
    Feb 11 2014
    2000 Audi S4, 1995 Audi S6
    Anaheim, CA
    20x9.5 ET35 DPE Flowtech
    255/35/20 Continental ExtremeContact Sport
    eMMOTION lowering springs
  20. #60
    Feb 16 2016
    Belgium
    love the wheels,the drop.looks really good :D
    how much is the car lowered ?
    too bad i live in europe...those wheels are probably only available in US :(
    i expected an agressiver look with that kind of fitment
  21. #61
    Feb 16 2016
    Belgium
    Quote Originally Posted by EmmanueleDesign View Post
    255/35/19 Continental ExtremeContact Sport
    You probably mean 255/35/20
  22. #62
    Feb 11 2014
    Anaheim, CA
    I am sure that you can get them shipped from US. The car is lowered about 1.7" (it's a non sport package).
    Thanks, fixed. Still getting used to that number
  23. #63
    Veteran Member Four Rings OmaHahn's Avatar
    Apr 07 2011
    1st owner '64 1/2 Ford Mustang convertible D-Code (dads)
    Nebraska
    Wheel Offset: 40
    Any reason you went with 255 size tires on 8.5 inch wheel? I was also considering 255 on my 8.5 but they're so much more expensive than 245 wheels - everywhere even Online like Tire Rack, etc. I found some sites that offer wheel calculators and the difference in size from 255 vs 245 is so minuscule I don't think the human eye could tell apart. Nice car!
    2009 A4 3.2 V6 - sold
    2014 Ford SHO, 3.5 twin turbo with mods, 490WHP/545WTQ - sold
    2021 Dodge Durango SRT
    1964 1/2 Ford Mustang convertible, D-Code (original owner, Dad's ride I'm storing)
  24. #64
    Mar 13 2009
    2012 S4
    Dallas
    Quote Originally Posted by OmaHahn View Post
    That was a typo, it should be 245 :)
  25. #65
    Feb 16 2016
    Belgium
    Thx for the quick reply
    Not that bad overall,if my search results are correct my setup has the sport package and that should be about a 0.8" drop from Audi. the damper/springs are getting more interresting, that doubles the score :D
  26. #66
    Dec 27 2016
    30.16' N 97.44' W
    Quote Originally Posted by zzz888 View Post
    My setup
    [IMG][/IMG]
    Is that stock suspension?
  27. #67
    Mar 26 2016
    Quote Originally Posted by Innominate View Post
    Stock sport package suspension
  28. #68
    Feb 16 2016
    Belgium
    you have the stock suspension = car isnt lowered , or you have the sport suspension = car is lowered factory ..... never heard of stock sport suspension ?
    Or im I missing something :D
  29. #69
    Senior Member Two Rings dbuxton13's Avatar
    Apr 20 2016
    Germany
    He just means the optional sport suspension. Makes for a 23mm drop.
    B9 S4
  30. #70
    Veteran Member Three Rings VipinLJ's Avatar
    Nov 23 2016
    Illinois
    You get aftermarket sport coilovers which are basically aftermarket sport suspensions.
    Hence, stock sport suspension = sport suspensions that came from the factory. As in, he didn't lower the car using an aftermarket product.
    2018 Audi SQ5 Prestige - Matador Red, DAP, S Sport pack, 21” V design, CWP, WWP
    2017 Audi A7 Prestige - Glacier White, DAP, Sport pack, 20" BOP, CWP
    2020 BMW 330i xDrive
  31. #71
    Sep 19 2006
    Mexico
    Quote Originally Posted by dbuxton13 View Post
    Sure about this? I thought sport suspension was 1 inch lower.
  32. #72
    Nov 23 2016
    Illinois
    25.4mm is an inch. What he said is just 2.4mm off. Almost close to an inch. I read somewhere too that the stock sport suspension lowers the car by 1".
  33. #73
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Wait, you guys already have the style grille for the B9 that you didn't have interest in making for the B8.5? That's frustrating.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
  34. #74
    Established Member Two Rings 029kid's Avatar
    Nov 13 2006
    Audi A4 2017 Avant 2.0 TFSI
    Oslo, Norway
    Will 245/35R19 8x19 ET30 be a good fit ?
  35. #75
    Nov 13 2006
    Oslo, Norway
    anyone ?
  36. #76
    Feb 04 2008
    Chicago, IL
    The stock offset is 40 so at 30 you will be 10mm difference. I would select 255 tires.
  37. #77
    Nov 13 2006
    Oslo, Norway
    I know the stock offset is 40, what would be the concern to go for 30ET?
  38. #78
    Sep 19 2006
    Mexico
    Quote Originally Posted by 029kid View Post
    If you are keeping the stock wheel/tire measure 245/35/19 on 8 wheels, you should be fine but right in the limit.
  39. #79
    Feb 04 2008
    Chicago, IL
    No concern unless you don't like the look or go with a really wide tire and have rubbing issues. AZ members don't dictate your concerns.
  40. #80
    Nov 13 2006
    Oslo, Norway
    Whats the best tyre fit for 8.5x19 ET35?
    235/35 or 245/35??
