Results 1 to 33 of 33
    Jan 11 2016
    Louisville, ky
    Running, but wrecked and unrepairable, Stage 3 01.5 Santorin Avant 6 speed
    Hello, my name is Gray.
    I am a long time lurker but never thought this would be my first post.
    Its time to let go of a project. It was a great car until unfortunately, an idiot in a suburban t-boned it. It is running with all vitals intact, but the body is beyond repair. It would make a fantastic donor car, wether you are looking to go stage 3 or need a solid drivetrain for a swap. The car has high mileage with around 220k (I will confirm later in the week as the car is currently sitting at a friends shop), but runs fantastically and when opened up approximately 30,000 miles ago the engine looked spotless. Crosshatching was still visible in all cylinders, etc. The car was tuned by VAST and ran extremely well. The car has been professionally maintained its entire life leaving many quality parts behind after its death.
    Parts include:
    Full black interior: The condition is worn but there are still many useable pieces
    Running 2.7t long block with all accessories working
    Frankenturbo hybrid k04's version 1: They pull strong with no adverse noises
    Tuned by VAST: 93 Octane, spiked at 24psi holding 23psi
    HyperBoost black diverter valves
    Ard Aluminum turbo inlet pipes
    VAST MAF housing
    Full Samco hose kit with clamp kit
    Ard/vast bi-pipes
    Induction Motorsports turbo oil feed lines
    Evolution Racewerks side mount intercoolers with uncut carbon shrouds
    Bosch 044 intake fuel pump
    Bosch 52lb EV14 injectors
    01E Transmission: Shifts perfectly with no 1-2 collar issues
    Clutch Masters FX400: The clutch had been slipping for a couple of weeks before the wreck
    Clutch Masters aluminum light weight flywheel
    Metal Slave cylinder
    Steel clutch line
    034 Motorsport density line motor mounts
    Stern Pro-Mount Transmission mounts
    Apical Rear Diff Mount
    Raxel front axels installed approximately 4k miles ago
    Podi boost gauge: Black on black mounted in vent
    Stainless Steel brake lines all around
    Bumpers are in OK condition but most every other body panel has some form of damage
    All Aftermarket parts have approximately 30k miles on them and are in good working order aside from the slipping clutch.
    I obviously did not list most stock parts but everything will be included with the car.
    I originally had plans to swap everything over to another car but I can't seem to find the time. If you are looking to upgrade, or for a swap, this is a good chance to pickup a great collection of used parts.
    The car is located in Louisville, ky and would require to be towed away (for obvious reasons). It is possible I could provide delivery for an additional fee.
    I am asking $3,000 but I am open to negotiation, so feel free to ask.
    I am NOT currently looking to part it out.
    I will post pictures later in the week or you may text me and I can send you some.
    You can contact me at (502) 544-0064 (texting is preferred)
    Jul 20 2013
    Nashville, TN
    Man that sucks...
    Can you text me pics at 615-210-5046. I'm north of Nashville, might be interested in getting it down here and parting it out if the price is right, there's a few parts I could probably use for mine.
    Thanks,
    Active Member One Ring B5S42.7TT's Avatar
    May 07 2011
    APR Stage 2 2015 Audi 8V S3, 2010 BMW N54 E90 335i xDrive M Sport Sedan
    Lake Bluff, IL
    I am interested in some parts for sure. Intercoolers with Carbon Fiber Shrouds
    Michael 1-847-212-0902
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    He just said not looking to part out...
    Jul 20 2013
    Nashville, TN
    I'm going to call him now and see if I can work something out to pick it up. If I do I'll part it out, mainly need the tranny.
    Oct 26 2015
    South Dakota
    Quote Originally Posted by Lear70 View Post
    If anyone buys this car for part out, save the front bumper for me
    Jul 20 2013
    Nashville, TN
    Roger that. Pretty sure I'm going to grab it and part it out quickly, keep the tranny and some small interior parts I've needed.
    I havr a lot of time off coming up (staycation) so will get a buddy and have it done pretty quickly.
    Will likely well the engine and ECU together as an assembly for a quick and easy Stage 3 kit, so if someone is looking for one, let me know.
    - - - Updated - - -
    Damn. No edit button on mobile. Sorry for spelling.
    Jul 01 2014
    'murca
    thats a super good deal, definitely worth the time to part out. i may be interested in some parts, post some pics when you get it :)
    Aug 24 2014
    Newport Beach, CA
    Interested in parts if this goes through.
    2024 M3 Comp xDrive
    Jul 17 2008
    Chi
    Quote Originally Posted by blakemorgs View Post
    I will pay whatever Blake is offering + $20. Let the bidding war begin!
    Oct 26 2015
    South Dakota
    Quote Originally Posted by shayrgob View Post
    Come on now
    Senior Member Two Rings Jay_Soprano's Avatar
    Nov 15 2010
    Audi A6 C6
    Orlando, FL
    Interested in parts.... Maybe about 5 of them
    Established Member Two Rings IbisB8.5S4's Avatar
    Sep 09 2015
    2015 Tahoe LTZ, 2008 Silverado
    Mount Vernon, WA
    ^^ you should take care of your other transactions before you start new ones.
    OP be wary of this guy jay_soprano, link below. just FYI so you can CYA.
    http://www.audizine.com/forum/showth...d-a-chargeback
    Jun 08 2014
    Vancouver, Washington
    Ditto ^^ I wouldn't deal with him if I was you unless he clears up the stuff with achb5.
    Jul 17 2008
    Chi
    Come on now
    I haven't heard anything from the owner of the car. I was thinking about picking it up but he hasn't responded to my text.
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by IbisB8.5S4 View Post
    Wow, good catch.
    2024 M3 Comp xDrive
    Nov 15 2010
    Audi A6 C6
    Orlando, FL
    Quote Originally Posted by christianb5s4 View Post
    Wow, good catch.
    Quote Originally Posted by MarlinFoundNemo View Post
    Go check out the thread... He's not telling the whole truth, just 10% of it. Read again to find out the other 90%... I'm legit and been legit for over 15 years on dozen of forums with the same user name and never no issue. I keep the same user name cause there is nothing for me to hide....
    Jun 08 2014
    Quote Originally Posted by Jay_Soprano View Post
    What is the 90%...?
    edit: jk saw it
    Jul 20 2013
    Nashville, TN
    I'm going to try to zip up and pick it up this weekend if the schedules line up, probably Sunday.
    Veteran Member Three Rings tbone5446's Avatar
    Nov 16 2006
    b5s4, 85 4runner T3/T4 turboed
    San Diego
    I would be interested in some parts if you do go grab it Lear70
    Veteran Member Three Rings cjk's Avatar
    Jul 15 2004
    2001 WB S4 Avant
    Seattle, Wa
    Interested in the stock mirrors plz
    REALTOR specializing in residential real estate throughout the greater PNW!
    https://kinzeleidsonteam.com//
    Constantly on my WB S4 Avant i
    Senior Member Three Rings audi-hammer's Avatar
    Aug 28 2009
    Buffalo,NY
    PMed and texted him saying I was a very serious buyer and no response to either
    Silvia = 02 s4 stageIII
    Jun 08 2014
    Quote Originally Posted by audi-hammer View Post
    You already have 2 B5's you dont need another to hassle with ;)
    Aug 08 2014
    New Zealand
    I am also interested in some parts if you would send to New Zealand. Please let me know if anyone can help :)
    Jul 20 2013
    Nashville, TN
    I can ship anywhere, just depends on what you need and whether I can get up there and grab it, trying to catch up with him today.
    Aug 28 2009
    Buffalo,NY
    Haha you can never have too many b5 s4's and someone I know needs an 01e swap ;)
    Jul 20 2013
    Nashville, TN
    Alright folks, I'm on my way to pick this car up. I'll start the part-out tonight and tomorrow.
    First for sale are the easy stuff to get first, headlights & front bumper & rad core support. I don't know what to ask on those because I haven't researched it yet but I will tonight, so please keep offers in line with current prices in the marketplace for OEM Audi stuff.
    Please make reasonable offers on parts.
    As for what I'm selling of performance parts, I'm going to make a separate thread once I get it back here with pics, but here's the list with prices that are new as far as I can tell, so keep your thoughts in line with normal discounts for used stuff you see on here and PM me offers if you like. I'd prefer to sell the whole engine with all upgrades that I'm selling with it, someone can get a NICE turn-key stage 3.
    ~?~ $700 - Running 2.7t long block with all accessories working
    Cost of parts when new:
    $1,900 - Frankenturbo hybrid k04's version 1, including Ard Aluminum turbo inlet pipes
    $ 600 - ECU Tuned by VAST: 93 Octane, spiked at 24psi holding 23psi
    $ 218 - HyperBoost black diverter valves
    $ 300 - VAST MAF housing plus Hitachi sensor, elbow, filter
    $ 600 - Full Samco hose kit with clamp kit
    $ 285 - Ard/vast bi-pipes
    $ 150 - Induction Motorsports turbo oil feed lines – will sell with whole engine or if parting out I may keep these.
    $1,435 - Evolution Racewerks side mount intercoolers with uncut carbon shrouds
    $ 275 - Bosch 52lb EV14 injectors
    $ 350 - Coil Pack Conversion Kit plus coils
    $ 750 - Clutch Masters aluminum light weight flywheel - I will sell this with a new steel insert - his clutch was slipping
    $6,648 – Total cost of upgrades if purchased separately, not including long block assembly
    Will take $4,000 for the engine with all performance mods attached plus shipping to save me the aggravation and time of pulling it all and shipping it separately. I will wrap it and strap it to a pallet, you pay shipping or local pickup 20 minutes north of Nashville. I can drop at a freight ramp in the Nashville area to save the pickup fee since it'll be at my house, I don't have a loading dock of course.
    Items I will keep:
    Steel clutch line
    Bosch 044 in-tank fuel pump – Keep
    3” Cat-back exhaust system
    Hood, left fender, right rear view mirror, speakers, radio head unit, a/c head unit
    I have an A4 hood on my car (it was a salvage repair and I couldn't find an S4 hood so I'll be putting his hood on my car) so if you need a black hood, mine will be for sale.
    You can also reply directly to [email protected]
    Jul 01 2014
    'murca
    lemme know if you'll sell the center console shift trim (no boot needed)
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    I need onyx visor clips, fog lights and rear diff carrier bushings. Have any of those?
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
    Jul 20 2013
    Nashville, TN
    From the pictures he sent me, it doesn't look like it has fog lights.
    Yes, I will be selling all the trim pieces. I should have those out in the next day or two, since I will need to disconnect the shifter linkage, and I'm keeping the radio and AC head unit.
    As for the rear differential stuff, I haven't even taken one apart before so I'm not sure which parts you need. I'm going to put them out on my car, other than that, all of that will be available.
    Jul 20 2013
    Nashville, TN
    Can't edit on the mobile version.
    I meant to say I'm not putting the rear differential on my car, just the amount. So anything from the rear differential is available.
    Jul 20 2013
    Nashville, TN
    Ok. It does have fogs, they're in good shape just not installed. They would interfere with the carbon IC shrouds.
    Car ran well. A little lifter tick from sitting for months but it cranked right up and loaded on the trailer well.
    Headed home now, the headlights are original xenon and work well. I will pull those tonight and create a new thread for everything.
    Jul 20 2013
    Nashville, TN
    New part out thread is here, a couple pics are up, more as I pull parts:
    http://www.audizine.com/forum/showth...1#post11377857
    Please respond in that thread gents, thanks!
