99 A4 2.8 30v with 187k.
Timing belt and water pump done about 50k ago. I think thermostat was done too at that time. Did my coolant temperature sensor (the one by the firewall on the passenger side) about 25k ago.
So I hop in my car for my 16 mile commute to work and as soon as I leave my driveway the dash tells me that my coolant level is low. I pop the hood and its a bit under the low mark in the reservoir. So, its really not that low, and I am surprised it triggered a warning. Anyway, I drive to work bc I can get free coolant near work.
As I am driving, I pay close attention to the temperature and sure enough it rises higher than normal. My temp level has always stayed at exactly the middle of the dial, but now it rises to about 3/4 way to the max, a bit past the first mark after the halfway mark.
So, I fill the reservoir to the max after work and drive home. Since then I have made the drive 2 more times and temperature level has risen to the same spot, and the coolant level in the reservoir has remained at the maximum.
Any ideas on what to check?
Also, am I risking damage driving at such temperatures?
