Results 1 to 6 of 6
    Senior Member Two Rings spike6339's Avatar
    Oct 19 2014
    Mk1 TT (225), V8 S10
    Mesa, Arizona
    Question EPC Light due to cold weather...
    So I have been having issues with my car due to cold weather. I have noticed that when it gets cold out( Below 0) My car starts a little slower as per expected, but it also kicks on the EPC light. Now I have a check engine light on, and it's just coming up with a couple different codes.
    P0171- BANK 1 SYSTEM TOO LEAN
    P0507- IDLE AIR CONTROL SYSTEM REVOLUTIONS PER MINUTE HIGHER THAN EXPECTED
    I had the same issues before minus the epc light..., and I ended up changing out the PCV, and everything went back to normal... Now it's returned! haha any help is appreciated :D
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    Is your car tuned?
    Oct 24 2015
    Perth, WA
    So colder air has more oxygen, and if this happens you may run lean for given the same amount of oxygen. I would look into the MAF or O2 sensors.
    My respray thread
    Oct 19 2014
    Mesa, Arizona
    Quote Originally Posted by brad281 View Post
    Is your car tuned?
    Nope there isn't a tune done, only thing I've really done is k&N. But it wasn't anytime recent. I'll take a look at maf and o2, and see if this is the issue
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    I have had this before. I wasn't tuned at the time also. I would turn the car off and restart it and most of the time it would at least allow the car to run normal. It would go away on its own and I haven't had the problem since I have been tuned. I just chalked it up to it being cold.
    What ever makes sense go with the opposite and you got it
    Feb 24 2004
    Minneapolis
    Spike, Hopkins here. I got the same two errors two weeks ago when it was below 0˚ every morning. Mine was the cheap-ass aftermarket PCV valve. See my thread here:
    http://www.audizine.com/forum/showth...8#post11335838
    If it's not the PCV, tolerances do change when it's cold, you might be sucking in air somewhere else.
    Not sure about your EPC light. Saw mine this morning, but I was hard on the throttle on a piece of ice.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
