Results 1 to 12 of 12
    Veteran Member Four Rings rockcandy's Avatar
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    New in box solid lifters (lower price)
    I've got a set of 034 motor sports solid lifters for the 2.7. Brand new in their unopened bags still. This was a second set I had for my motor setup. I think they're $600. $450 shipped in the us. Again, never even taken out of their bags.
    Lower price-$375 shipped
    Someone in here has to be building an engine!?
    Veteran Member Three Rings Cacti's Avatar
    Nov 10 2011
    MI
    Marshall what cams are you running with these?
    Great seller BTW!
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    I have loba cams in my setup. I'd have to dig up the specs
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    Bump
    Home of the slowest s4 of 2014
    I buy 2.7 engines. Either short/long blocks. Message me!
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    $400 shipped new price
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    bump for lower price
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    Someone show their engine some love
    Feb 17 2016
    2001 b5 passat stage 3 2.7t swap
    cincinnatti
    can you run these with stock 2.8 cams?
    Veteran Member Three Rings arotished's Avatar
    Jul 04 2010
    Norway
    Quote Originally Posted by rockcandy View Post
    LOBA Solid cams:
    Intake: duration (0,1mm) - 254° duration (1,0mm) - 214° max. lift - 9,00mm
    Exhaust: duration (0,1mm) - 260° duration (1,0mm) - 218° max. lift - 10,8mm
    Peak angle - 110°
    Quote Originally Posted by AudVW View Post
    I guess you can but I dont see the point as you will loose the advantage with solid lifers vs hydraulic lifers.
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    Quote Originally Posted by arotished View Post
    LOBA Solid cams:
    Peak angle - 110°
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    Bump
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    Btt
