Results 1 to 7 of 7
    Jan 25 2012
    Mckinney, Tx
    Talking Thinking of buying a 2005 A6 Quattro 4.2 with a bad transmission
    I don't have much info about this vehicle, but this is what I know. It has 255,000 miles and there is an issue with the tranny.
    This is what the owner told me.
    Audi dealer said the transmission my need work.
    I was driving it a few months back, stopped at a traffic light, and went to go and it would. The engine was running but car wouldn't move. Had it towed to my house about 4 months ago.
    It's sat there ever since.
    She is asking $2100 for it.
    I don't have any more info to give you guys about this vehicle, my question is am I crazy to buy it I should I pass? If its still for sale I'll see it on the 14th, as its not a local vehicle.
    Thanks Shane
    Jul 17 2011
    Sin City, USA
    Are you planning on doing the work yourself?
    '09 C6.5 A6
    Established Member Two Rings kocyk123's Avatar
    Nov 02 2015
    2001 Audi A8L
    Harwood Heights IL
    I would personally pass on this one. You are looking at huge tranny bill plus you don't really know what kind of maintenance the engine and suspension needs. It all might cost you the price of a lower milage, good working C6 with less wear and tear inside. My $0.02
    Current rides:
    1. 2013 Hyundai Azera Tech 50k miles
    2. 2001 A8L 4.2 Quattro 211k miles
    Sold:
    1. 2007 A6 4.2 FSI Quattro 77k miles
    2. 2007 Acura TL Nav at 86k miles
    3. 1996 A6 Quattro at 155k miles
    Jan 25 2012
    Mckinney, Tx
    I am planning on a buddy of mine to do the work.
    Jul 17 2011
    Sin City, USA
    At this point, it is a crap shoot. IF it is only the tranny AND you are not paying someone labor to fix, then it may be doable. However, with 255K on the Car I start to worry about other issues with the motor.
    At minimum, replacing timing chains, guides and tensioners is a must since you will already have the motor and trans out and separated.
    If it were me, I would pass unless you have the ability to test several different things (compression and leak down, run full diagnostic scan with VCDS, etc.)
    '09 C6.5 A6
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    This. Seriously OP run away from the car unless you get it for free.
    You will need to replace every seal, every accessory (power steering pump, water pump, etc.) the timing chain guides all very soon if not immediately. Then you have the whole suspension and wheel bearings....
    Jan 25 2012
    Mckinney, Tx
    Quote Originally Posted by FormulaElement View Post
    I agree with you all, I just wanted some input to decide, and I will stay away from this vehicle, unless I get it dirt cheap..
