Results 1 to 19 of 19
    Active Member Two Rings A6AJ's Avatar
    Dec 02 2015
    2014 Toyota Prius (wife's), 2010 Toyota 4Runner (sold), 2004 GMC Envoy (sold)
    Iowa
    2006 A6 3.2L (77k miles) headed to shop..
    As with several C6 3.2l the starting of my A6 has become hesitant at a cold start. It's very similar to other posts on the forum. Battery? Plugs? Carbon build-up? Fuel filter? Injectors? It does appear to start better after turning it to "accessory" mode for 5-6 secs and then going to full engine start. If I don't do that, it acts as if it's not going to start for about 3-4 secs and then kicks on....
    That was pretty much the only issue that I noticed after purchasing it used a little over a month ago. The dealer said it may be caused due to sitting on the lot for awhile and recommended me to take it for a "drive" of more than 100miles. I thought that was ridiculous but ended up taking it out for a 120miles trip to see the parents. Obviously, that didn't fix it.
    Now, I've started to smell a hot/slight burning smell after driving it for awhile in the garage after I turn it off or while idling at stop lights.
    It's scheduled to go in on Wednesday at 10:30am for service. Any questions that you more experienced Audi owners would advise me to ask?
    I'll keep you all posted and update the post after the service. Any advice would be great, cheers.
    2006 Audi A6 3.2L Quattro (Oyster Gray), my first and most definitely not my last.
    Nov 30 2009
    '07 C6 A6 Quattro
    I'm curious to see what the solution is.
    '07 C6 3.2 Quattro, no mods
    Senior Member Two Rings Saifxnyc's Avatar
    Oct 19 2012
    Pittsburgh, PA
    Quote Originally Posted by A6AJ View Post
    I had the issues you describe. I did a carbon cleaning and replaced the fuel filter. It starts a bit better. I also ran a can of sea foam in it after the carbon cleaning the get rid of any remaining gunk in the car. Recently just replaced the battery. Because car would attempt at starting but would barely make it. Hopefully it is something common and easy.
    Dec 02 2015
    Iowa
    Thanks for the replies...I'll let you know what happens.
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    My first recommendation is to start with the fuel filter. $30 dollar part that takes no more than 15 minutes to replace is a no-brainer. I had exactly what you described on both my B7 and my previous C6. Replaced the filter, and starting problems went away.
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Dec 02 2015
    Iowa
    Thanks for the reply Monsta.
    Now for some bad news....I went out this am and found a small amount of oil underneath the engine compartment after pulling out of the driveway. I'm def thinking the burning smell is that of oil.
    Glad it's headed in tomorrow.
    Jan 30 2014
    1st gen Q45s
    FL, USA
    This sounds like oil leak, start with the valve cover gaskets.
    Dec 02 2015
    Iowa
    Sounds great, will do just that.
    May 17 2009
    Idaho
    Quote Originally Posted by FL C6 Avant View Post
    That and next would be timing chain covers. Pull the splash guard off and see if the oil leak is at the front or the rear of the engine.
    Current:
    2002 1.8t A4 Sedan
    Dec 02 2015
    Iowa
    Stealership says Valve Cover Gaskets and quoted $880 for parts and labor. I just left the Indie shop in town and am awaiting a quote from them. I'll update when I get that.
    It doesn't matter much but the service guy at the indie shop was not a d-bag like the dealership. He was genuinely nice and even asked if they checked the timing chain covers, which they didn't. He's going to.
    I'll keep you guys posted.
    Dec 02 2015
    Iowa
    Indie shop quoted $450 for the parts and labor on the gaskets. Wow, what a difference. I confirmed they'd be using all OEM parts too.
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    They are really easy to do and you can do it for under $200 yourself. $450 isn't bad though. Audi dealerships are really expensive unless you have a good relationship with the service advisor/manager.
    Dec 02 2015
    Iowa
    I need to learn more around my car. Never been much of a grease monkey but I guess better late than never.
    The Indie guy is gonna actually do em for $400. It goes in next Tuesday. He was flabbergasted that the Audi dealer in town was actually charging that much.
    Thanks for all of the replies and comments.
    Veteran Member Three Rings mixtery's Avatar
    Jan 26 2011
    Out East
    Valve cover gaskets are one of the easier things to do on the 3.2. They are like $20 each.
    But a lot of times it's the Timing chain covers that leak on the exhaust. Just went through this. It's a bit more involved to do but not expensive.
    The covers use a sealant and it dries out. Believe there was a tsb about it.
    Jul 17 2011
    Sin City, USA
    The valve covers on our cars are plastic. Audi replaced my valve covers because I took it in 3 times for leaks previously that they claimed to have repaired. On the 4th visit, they chose to replace both valave covers becasue they believed that the covers warped causing a bad seal. That ewas approx. 8 months ago and Low and behold I developed another oil leak. Back to the stealership I go.
    '09 C6.5 A6
    Jul 02 2013
    406, MT
    Sorry to hear. When i did my valve covers i put RTV on them along with new gaskets to make sure they didn't leak.
    Dec 02 2015
    Iowa
    Definitely not good SinCity. I hope they get that figured out.
    Formula- RTV a sealant?
    Jan 30 2014
    1st gen Q45s
    FL, USA
    RTV= Room Temperature Vulcanising
    it is silicon rubber that goes on as a paste and somewhat hardens. it can fill in voids, so yes a sealant.
    But don't go crazy with it....
    Dec 02 2015
    Iowa
    Gotcha. Thanks.
