    Senior Member Three Rings dba4's Avatar
    Sep 02 2010
    Markham/Ontario
    Removing CD's from a radio that is out of the car
    I have a Symphony 2+ that is out of the car and i want to remove the cds. is there an easy way to do this?
    my car is a symphony 2 and have not installed it yet due to wiring issues. I had an RNS-E and when i tried to install the Symp 2+ you could hear the cd's shuffleing around but wouldn't power up the unit.
    I want to get the cds out for the previous owner.
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Quote Originally Posted by dba4 View Post
    Should just be a couple of screws on the top (or bottom) if the cd tray is right on top. Take pictures before and during the removal to make sure you see where things go especially when springs start flying around.
    Mar 24 2013
    Oakdale, CT
    Try using test leads to attach a 12v power source. You should then be able to just hit eject. You may need the unlock code though.
    -Adam
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    Be VERY careful if you decide to take the top of the unit off to access the CD's. It isn't very difficult to do this way, but there are little arms that act as the cd changer and can be easily knocked out of position creating all sorts of errors that take a lot of fiddling to remedy.
    This is what you will see if you take the top off, crappy pic back when I had to dissect one to fix the CD jam error.
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Sep 02 2010
    Markham/Ontario
    tried to do this a while ago with no luck. does anyone know which pins to hook up to get it to power up. using the 12v with ground only had the cds shuffeling around. radio did not power up.
