Results 1 to 6 of 6
    Nov 11 2010
    Rochester, MN
    Slow seat belt retraction
    Hi guys,
    I dunno what the deal is, but in my B7 S4 both front seat belts are slow in retracting onto the roller. Is there any way to tighten/speed that up? I never had a problem like this on my old B6 S4.
    19" B8 S5 Peelers
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Could your seat belts be dirty? I came across a post before where someone had that problem. Cleaned the belt with soap and water. Let it dry and it became faster.
    I know my fathers work van has that problem and his belts are dirty.
    May 20 2010
    I have this issue particularly with my driver's belt. Enough that I think it's retracting but then flops and gets in the way of closing the door.
    Guess I'll try cleaning it. Thanks for the tip!
    Nov 11 2010
    Rochester, MN
    Quote Originally Posted by ABanT View Post
    I suppose they could be, but using water on them currently is a no-go, as it's below zero for the next week. I would love it if the solution were that simple, though.
    19" B8 S5 Peelers
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Same issue as well, has been this way since I purchased the car.
    Will try this as well and report back!
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Active Member Two Rings nucciOMG's Avatar
    Jan 07 2014
    Subaru Forester, Ducati Monster S4.
    Norwalk CT
    Same here. I looked into the issue for about 30 seconds, I guess you can pop off the b pillar cover, and adjust it. Someone who more knowledge will have to explain further.
    B7 S4. 6SPD. Catless Milltek, QTP wireless cutouts. Tein springs. 19" VMR 708s.
    KCCO!
