Results 1 to 17 of 17
    Aug 19 2013
    minnesota
    ECS KO4 dental drill
    I've had my KO4 on for about 1 year now, today heading home from the grocery store my turbo suddenly began emitting a loud dental drill sound. Is there anything else that could possibly make that sound? Do I have any kind of warranty from ECS?
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Aug 26 2005
    Nothing else I can think of. Inspect the turbo ASAP, check for side play of the compressor impeller and turbine shaft bushings. Make sure the lube oil feed line is clear, not partially plugged with sludge. Replace the lube oil feed line with a new oil feed line to insure the line is not blocked. Check the engine oil pressure at the oil filter base using a pressure gauge connected to the filter base with a 10mm X 1mm thread pitch fitting and a hose to the gauge.
    Vorsprung durch Technik
    Aug 19 2013
    minnesota
    okay I should have some time this week...
    Registered User Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Portlandish
    Check the fasteners and gasket where the turbo meets the manifold. If you have a leak there, the sound is metallic and drill-like.
    Dec 05 2007
    If it is an RP turbo, they are junk.
    Aug 19 2013
    minnesota
    Quote Originally Posted by Doug@FrankenTurbo View Post
    She's tight on there, I don't think it's loose.
    Aug 19 2013
    minnesota
    What's an RP turbo? This is a Borg Warner from ECS.
    Oct 02 2006
    Wadsworth,OH
    Seems odd that a Borg Warner turbo would show signs of failure that early. Typically shaft play will accompany the dentist drill sound. Remove your headlight then remove the turbo intake pipe. This will give you access to the compressor wheel. If it has excessive play up and down it would be safe to assume the CHRA is shot.
    Jason
    Veteran Member Three Rings Audi body's Avatar
    Jan 03 2013
    bike and a pit bull powered pair of rollerblades!!
    the woodlands tx
    Usually they never fail unless they are starved if oil.
    Aug 19 2013
    minnesota
    is the k04 double channel journal ?
    Oct 19 2009
    Portlandish
    OP -- it's possible you have a premature failure owing to an oil issue. But I'd still recommend you check the gasket at that flange. If it's compromised, you get that sound. If you pull the inlet to feel for shaft play, you are looking for movement fore and aft. Side to side is not important.
    Aug 06 2014
    Melbourne/Australia
    Hi Doug,
    I thought a tiny amount of fore-aft play was normal, and "side-side" play should be zero?
    Are you saying if there is fore-aft movement at all the CHRA is on its way out (if not rooted already?)
    Cheers, Matt
    Aug 19 2013
    minnesota
    I bought an oil pressure tester with multiple fittings and an excellent easy to read jumbo gauge from harbor freight for 21 bucks on sale, normally 27.
    It's a quality tool it comes with a m10 x1 fitting - you will need teflon tape and a bit of a turn to prevent a leak at high rpm the threads seem to bottom out in the hole - http://www.harborfreight.com/engine-...kit-98949.html
    I plugged it to the port on the top of the filter housing.
    cold start idle 20 degrees - 71
    25 minutes at idle 49
    40 minutes 37
    2k rpm for 5 minutes 64
    return to idle 30
    idle 10 more minutes 29
    2k rpm 62
    I wiggled the manifold and the turbo and all I could be certain was moving was the whole motor. I will remove the bumper tonight or tomorrow and inspect the turbo. I have to put a new starter in my old spare galant before I can do anything else.
    Veteran Member Four Rings jayiszraw's Avatar
    Aug 03 2009
    swfl
    Quote Originally Posted by ozMatt View Post
    Hi Doug,
    Cheers, Matt
    Its actually the opposite. Even a brand new turbo may have some slight side to side especially with no oil. The fore and aft play will tell you if the thrust bearings are shot
    2.7 swap in progress
    Aug 26 2005
    Quote Originally Posted by jayiszraw View Post
    That is true, however when the turbo makes a dentist drill noise the concern is that the compressor impeller or turbine is touching it's housing wall, that will damage the impeller or turbine.
    Sudden excessive bushing radial wear can only be caused by lubrication failure. or severe imbalance from FOD, etc.
    Aug 19 2013
    minnesota
    What do you think about these bearing upgrade kits? I have read the new generation ko3/ko4 are dual channel for better stability? This kit seems to be single channel but more galleries and larger.
    http://www.ebay.ca/itm/111685865336?redirect=mobile
    And video linked to AZ. https://youtu.be/99yMB5RII1U
    Jan 03 2013
    the woodlands tx
    Best bet is to send it back for warranty. At least in my opinion.
