Results 1 to 7 of 7
    Apr 14 2014
    concord nc
    Almost blew engine. ..eek. watch out for that boost controller!
    looks as if one of the balls on the turbine side of boost controller is missing pieces. First time I've ever come across this.
    Nov 03 2011
    All Over!
    1986 Type 85 Audi 90 quattro
    Apr 14 2014
    concord nc
    If you didn't get it. A shitty spring type Boost controller runs on a spring and two ball bearings. One of them got eat up by heat and warped the spring too and caused a massive boost leak.
    Jun 21 2005
    Milton, Ontario
    Mine wasn't the cause of heat however, it was a build up of moisture that ended up seizing the ball bearing and making it stuck to the inside of the mbc. Just run a little fuel filter inline right before your manual boost controller. This made me boost to 40psi. At least I was running meth on a built motor, but I stretched the stock headbolts.
    Also FYI, you posted this thread in the Projects & Builds sub forum.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Dec 05 2007
    Also not sure how he was allowed to make a thread in here
    Apr 14 2014
    concord nc
    Oh shit my b
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    Quote Originally Posted by SleeperAvant View Post
    What turbo did/do you have that stretched the stock head bolts?
