My sonīs A4 Q was leaking oil in differential and when I was cleaning the flange, joint before removal
I felt like it was loose so I assumed that the bolt in middle was loose that was holding the flange.
When I did change the seals I measured that right flange could be moved in and out approx. 2mm / 0.079in
Bolt in middle of flange was tight
Left side is OK
No abnormal noise, oil looks fine when I changed oil after replacing flange seal.
How to fix this issue have someone a blueprint of the differential how to adjust the clearance?
It is Quattro weather in Sweden and my son like to have some fun with the car....
