Results 1 to 4 of 4
    Apr 10 2012
    2003 Audi A4 1.8T Quattro
    Fort Worth,TX
    Leaking Power Steering fluid , need advice
    So I noticed a small puddle under the drive side in front of the wheel. When I look under the car the 2 lines coming from the Power Steering cooler are wet. The cooler itself is dry. When I run my hand up one of the lines toward the rack and pinion its a little wet at the banjo connection but nothing massive.
    The power steering reservoir was low as well just below the min. mark.
    Should I just try to tighten the hose clamps on the lines? IS there something else going on I should look for? Thanks !
    2003 A4 1.8T Quattro Auto, Custom Stage1 tune, N70, 550cc Fuel Injectors, B7 console (with cup holders!)
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Had rhe same issue a few years ago. Tightened up on the clamps and problem solved.
    Apr 10 2012
    Fort Worth,TX
    that makes me feel better that its hopefully not something major like a steering rack. I will take a look tomorrow and will check the boots as well to make sure there isn't fluid in there also.
    Veteran Member Four Rings Tone-Dogg's Avatar
    May 06 2007
    2020 Q3 P+
    Hartford, Connecticut
    I second old guy, tighten the banjo bolts, also you can see if the boot has fluid in it, if it does, the internal seal on your rack has let go.
    Sent from my SM-N910V using Tapatalk
    2016 Q5 3.0T Quattro P+ Sline Black Optic
    2020 Q3 2.0T Quattro Premium +
