Results 1 to 14 of 14
    Active Member One Ring jacob39's Avatar
    Jul 27 2013
    39 chevy rat 00ram2500 custom tube bugy
    carson city nv
    my 5spd died what are your suggestions
    It popped out of gear and left me on the side of the road. My plan is to pull it rebuild it. But I was wondering what you guys would do? Do you have something better then the stock 5spd?
    99.5 A4 quarto 5speed 139,000 miles
    If a guy has sex with a prostitute while she is passed out is that Rape or Shoplifting
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    lol a rebuild is foolish if your on stock power. Cheapest thing would be to get a used transmission, I did that 2 times with my 97.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Jun 30 2008
    Erie, Pennsylvania
    Popped out of gear, eh?
    It might just be the "stop screws" (aka "slider bolts") for the shifter relay shaft. One or both of them may have sheared off. This is one of the few failure points on the 01A/012 5-speed transmissions. Luckily these bolts are externally accessible and do not even require removing the transmission from the vehicle to inspect or replace.
    Check out this thread and others:
    http://www.audizine.com/forum/showth...-in-first-gear
    This one has pictures of the bolt locations:
    http://www.audizine.com/forum/showth...Shifting-issue
    Jul 27 2013
    carson city nv
    I should probable fix that. thanks walky.
    I do not have those symptoms. with my problem I can shift fine any and all gears, it just wont catch anything if I don't touch the clutch it will grind but not ingage. like the gears are not syncing up. I am going to go put it on stands now and check and hope.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    I wonder how many stock transmissions have failed at stock power? Given that plenty of people are pushing them at 2-3x power, without too many issues.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Dec 10 2013
    Borden, Ontario, Canada
    Quote Originally Posted by Avant Nate View Post
    I would think it's a poor maintenance issue more than anything
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    Quote Originally Posted by Bordom View Post
    Or bad shifts, or bad clutching, or an abusive aftermarket clutch...
    Mine is failing and it is not from lack of maintenance but it could be due to stupid after market parts decisions I've made.
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by jacob39 View Post
    Every gear, eh?
    Pretty much sounds like the shift collars are not engaging due to shift forks not moving far enough (ie: "not shifting fine" - probably due to slider bolts) - OR you have a broken CV joint on one of the axles. If the problem was the "gears not syncing up" that would mean that you have stripped the teeth of ALL 5 gear sets, which simply isn't possible. The gears are quite likely just fine. But they either aren't being fully selected due to an internal or exteral shifting linkage issue, or one of the CV joints is broken. There's an outside possibility that you've broken one of the differentials (front, center or rear), but that is quite rare, especially on stock power.
    I'd check all the CV joints before you bother with the bolts I mentioned. That sounds more likely to me. Safest way is to put it on a lift or jack stands (all wheels lifted) then put it in 1st gear and see what parts are spinning.
    Jul 27 2013
    carson city nv
    Jacked up and the front passenger outer cv separated.
    Established Member Two Rings harrowb5's Avatar
    Dec 10 2014
    Davis, CA
    01E swap time and use the 01E's from JHM.
    99 B5 A4 H&R race springs with koni yellows, giac x, Forge Splitter diverter valve, forge turbo inlet pipe, and 2.5 in exhaust , and a Diy fmic using a JHM core
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Quote Originally Posted by DND View Post
    wrong fluid too GL5 will kill it
    SOLD the GOINHAM A4 ---> GT2860 Project
    Senior Member Two Rings CoyneJ's Avatar
    Dec 29 2015
    B5 S4
    Illinois
    i had GL5 for like a week in mine would that really damage it?
    i noticed it shifted harder so i bought the right one G 005 000
    Nov 17 2011
    Fredneck Maryland
    A week, most likely your ok its more like 5000 miles of gl5 will kill the syncros. Yellow metal. I would flush it again to be sure but that's your call.
    Gear oil Info clicky
    Sent from my SM-T560NU using Tapatalk
    Dec 29 2015
    B5 S4
    Illinois
    i had it only for around 100 miles, thanks for the info, only changed it to proper one because of the the shifting being harder now i know that i just saved my transmission :)
