Very pleased with feel of clutch & flywheel. First got it back and wondered why they didn't make the car like this from the factory, I look forward to freeway on-ramps now
With the exception of this clutch kit (and cone filter for the sake of being thorough) car is all stock. Seems more eager to pull from low RPM now, but I get this clattery valves, bogging the motor sound when I try to pull from ~2000rpm. With the window down I can hear it reflect off of the car next to me when I take off. In my mind I attributed this to the mass of the flywheel being reduced by 50% and inherently having less inertia available to pull from a low RPM. Like, when climbing a hill it feels like I should shift down sooner to avoid lugging the motor. On a steep hill this will happen as high as 2500rpm. During the past weeks I've adapted to it & just run a lower gear than normal & hold the gear longer before shifting.
So my question is, is this just a characteristic of the new hardware? Or is there a deeper underlying issue? Would quicker spool from a chip, or higher-flowing exhaust help counter the low-rpm flat spot? It doesn't really bother me once I figured out how to work it, just requires more driver seat interaction
