Originally Posted by
fyremanpat
3.71-3.86 g/s at 800 RPM idle.
Sounds pretty normal. Maybe a touch on the high side for a manual transmission. What is your engine load at idle? Typically i see loads at 16-18 but my idle g/s is usually just under 3 g/s. If I turn on a bunch of stuff that drags on the engine my idle g/s goes up to around 3.4 and the engine load goes to a max of 20.25
How does that compare to your engine load reading?
The reason I'm asking is because from what I can gather out of the Bentley is that the P1857 has to do with expected versus actual engine load in conjunction with the automatic transmission. Again, I don't know why you would be getting a P1857 but if your engine load at idle is significantly different than mine at idle it may help in figuring out what is causing the problem.
Edit: And did you try clamping off the vacuum lines and looking for a difference in g/s?
