So I'm having issues with my heat, car is a 2004 ultrasport, all maintenance up to date etc
Symptoms:
-I can let my car idle for 15-20 minutes and the fan will still blow cold air
- after idling I can drive for 15+ minutes and the fan will blow room temperature air
- if I drive for a 20+ minutes or on the highway eventually the hot air will start to blow.
- engine temps are perfect
- no visible coolant leaks
- one thing to note, may be unrelated though, is that my center dash vents blow very minimal air, so little that I can barely feel it with my hand on the vent
I've read a ton of threads but am looking for some more specific insight, this is super inconvenient since the temps are starting to drop down to -30 degrees Celsius. Any insight would be wonderful! Thank you!
Sent from my LG-H812 using Tapatalk
