Page 1 of 5 123 ... LastLast
Results 1 to 40 of 179
    Senior Member Three Rings B6_A4_Kid's Avatar
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Calling Audi gurus!
    My car just won't ever run right, I am not sure what my first plan of attack should be. Here are all of my fault codes, sorry I only have vcds lite for right now. Wanting to upgrade soon though.
    VCDS-Lite Version: Release 1.2
    Saturday, 09 January 2016, 16:10:44.
    Control Module Part Number: 8E0 909 518 AK
    Component and/or Version: 1.8L R4/5VT G 0004
    Software Coding: 0016751
    Work Shop Code: WSC 63351
    VCID: 79856EE770C1
    10 Faults Found:
    17519 - Oxygen (Lambda) Sensor Regulation: Bank 1: System too Lean
    P1111 - 002 - Lower Limit Exceeded
    17887 - Shareware Version. To Decode all DTCs
    P1479 - 008 - Please Register/Activate
    17544 - Shareware Version. To Decode all DTCs
    P1136 - 001 - Please Register/Activate
    16795 - Secondary Air Injection System: Incorrect Flow Detected
    P0411 - 002 - Lower Limit Exceeded
    18010 - Shareware Version. To Decode all DTCs
    P1602 - 002 - Please Register/Activate - Intermittent
    16683 - Shareware Version. To Decode all DTCs
    P0299 - 002 - Please Register/Activate - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 008 - Implausible Signal - Intermittent
    16685 - Shareware Version. To Decode all DTCs
    P0301 - 008 - Please Register/Activate - Intermittent
    16688 - Shareware Version. To Decode all DTCs
    P0304 - 008 - Please Register/Activate - Intermittent
    18339 - Coolant Fan Control Module (J293): Malfunction
    P1931 - 001 - Upper Limit Exceeded - Intermittent
    Please help me out guys, I'm at a loss here
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I'm still waiting on a new suction pump, I superglued the other one but while doing to I broke the breather check valve, the small tab off to the side. I have ordered that aswell, do you think this is what's causing these codes?
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    The pump is still leaking even after I glued it
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by B6_A4_Kid View Post
    I assume you are referring to this check valve when you mentioned the "small tab to the side".
    The side port on that check valve is what charges the vacuum canister located underneath the front drivers side fender. The vacuum canister is what provides vacuum for the N112 that opens the combi valve on a cold start. If the combi valve doesn't open you will get a P0411.
    That broken side port will also manifest itself as a vacuum leak which will give you the P1111, P1136 as well as the P30X misfire codes.
    Heres the part number for the check valve: 058-905-291-B It's a $40 valve from the dealer. Here's the best price from anywhere: Clicky click® I bought 2 of them just to have as spares if I ever need one. One in the trunk and one in the garage.
    Aug 26 2005
    Help us help you by googling all the DTC fault codes and fill in the list of problems. I could do it but it is time consuming.
    For the first DTC, showing lean fuel, several possible causes. Check for vacuum leaks in the vacuum hoses. If the SJP is leaking fix that first. Once the list of faults is filled in, there will be advice about how to deal with those. After copying the DTC numbers showing now, try clearing all the existing DTCs and see what DTCs reoccur.
    Vorsprung durch Technik
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Sounds good. Sorry guys I'll switch them over for you next time. I have ordered that check valve old guy posted. So I will throws those parts on hopefully by the end of the week. Is driving it like this going to cause anything horrible?
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Also what do I do about the coolant fan control module and the vacuum brake booster? Sorry for all the questions
    Dec 28 2006
    Western Maryland
    That broken check valve will reduce vacuum to the brake vacuum booster. That should correct itself after replacing the check valve. Try resetting all your codes and see if the intermittent fan control module one comes back. Post up if it does and we will figure it out.
    See if you can temporarily plug up the broken port on the check valve. You will still have an issue with the SAI code but it should stop the lean code and misfires.
    Aug 26 2005
    No.
    Senior Member Two Rings Captain_Panic's Avatar
    May 01 2015
    B6 A4T, VS800, C6 A6, Conversion Van
    Dublin, Ohio
    Have you checked your spark plugs to see how they're burning?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Looks like vacuum leaks to me, probably form the SJP and the check valve. You and unplug you MAF and drive the car, you will not really have any power though.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I checked the plugs and they are a little on the white side for my liking, but they are bkr6es and from what my boost gauge leads me to believe its been tuned. I will swap them out for bkr7es when I get my other stuff in the mail and I will report back.
    How would you recommend me plug the breather for now?
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    I just came in here to let you know that your Audizine name is my Xbox live name....
    Very strange.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Sorry about that man, I just came up with it and decided to use it
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Well I have put my new parts in and there is no vacuum leak, and I am still running the bkr6es until I can get 7s and it's still misfiring like crazy! not sure what I need to do to fix this?
    Dec 28 2006
    Western Maryland
    Now that you have fixed your vacuum leaks try resetting all of your DTC's and see what comes back. It could be any number of things. How does your wiring harness to the coil packs look? Pull back on the plug cover and look for any cracked wires that could be shorting out. How old are the plugs?
    Also take a look at your MAF g/s at idle and see what it reads. You could also try unplugging the MAF sensor and see it the engine smooth's out. If it does that would indicate that you still have a vacuum leak somewhere.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I have reset the codes since I did that and the codes came back about a day later. My harness didn't have the rubber insulators and everything was bare copper when I got it. I have electrical taped it as best I can, but it hasn't been an issue until my vacuum leaks happened. The plugs have at most a 1000 miles on them
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Just out of curiosity, it won't affect how the car is running or make it run "rough", but do you hear your SAI pump run when you start the car? Front passenger side?
    Dec 28 2006
    Western Maryland
    Which ones came back? ALL of them? Is the misfiring just at idle or all the time? Have you checked your MAF g/s at idle? (MB 003) Did you try unplugging the MAF sensor to see if anything changes?
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    It doesn't do it at idle, and the cel only comes back on when I am boosting at 16 psi
    Dec 28 2006
    Western Maryland
    Do you get a flashing CEL? Does the misfire stop as soon as you get out of boost? Which DTC's return?
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Nothing flashes, and the misfire seems to be constant. It's only really bad when your on the freeway going 60ish, it will just vibrate like crazy! As soon as you let off its smooth but once you hit the gas again it starts again. Cold start seems to be good but once it's warmed up the idle is really rough
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Not sure what to do about it
    Dec 28 2006
    Western Maryland
    You mentioned that you are getting a rather severe vibration under load that goes away as soon as you reduce the load but no flashing CEL indicating a misfire. Are you sure the vibration is coming from the engine? Any chance you are getting a vibration from one of your drive axles?
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    It doesn't happen every time, it's done it before but it was a loose spark plug. Fixed that and it was good until now
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I don't think it's my CVs, I mean it could be. But it is still misfiring so I want to fix that and see if that's what's causing it before I dig into drivetrain components
    Dec 28 2006
    Western Maryland
    How new are your coil packs?
    Sometimes they start out only failing under load. I have had two that failed that way. I have had others just quit all at once.
    Aug 26 2005
    Replace the damaged wiring. No matter how well you tape wrapped the bare copper wires, that is not adequate insulation to prevent malfunctions of the associated electrical components. With the wiring insulation damaged, the electrical terminals are likely in poor condition also, negatively effecting reliable electrical contact of the wiring circuit terminal connections.
    Jun 30 2008
    Erie, Pennsylvania
    10 Faults Found:
    These 3 point to a fairly large vacuum leak - probably in and around the line to the brake booster. Could be the suction jet pump is cracked open or the large "L hose" is ripped.
    17887 - Brake Boost Vacuum System: Mechanical Failure
    P1479 - 008 -
    17544 - Long Term Fuel Trim Additive: Bank1 System too Lean
    P1136 - 001 -
    These 2 are probably not important right now.
    18010 - Power Supply (B+) Terminal 30 Low Voltage
    P1602 - 002 - Intermittent
    Under boost code. Could be related to the vacuum leak discussed above. The leak may be both a vacuum and boost leak.
    16683 - Boost Pressure Regulation: Control Range Not Reached
    P0299 - 002 - Intermittent
    These 3 could be related to the lean condition.
    16685 - Cylinder 1 Misfire Detected
    P0301 - 008 - Intermittent
    16688 - Cylinder 4 Misfire Detected
    P0304 - 008 - Intermittent
    These seems to be a separate issue. I'd leave this one for last.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I have driven 158 miles since i last reset the codes, I just pulled them.
    Monday, 25 January 2016, 19:39:37.
    VCID: 79856EE770C1
    3 Faults Found:
    P0299 - 002 - Lower Limit Exceeded
    18339 - Shareware Version. To Decode all DTCs
    P1931 - 001 - Coolant fan control module
    17522 - Shareware Version. To Decode all DTCs
    P1114 - 008 - 02 sensor?
    Dec 28 2006
    Western Maryland
    At this point I think a boost pressure test would be in order.
    The P1114 has to do with the rear O2 sensor. That one should not cause any performance problems.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Okay, I've still got the tennis ball from when I did it to my brothers car so I'll do that tomorrow when I'm off from work
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I am planning on doing this just pushing it as long as I can, and since the codes I just pulled show no misfiring I think I can push it a bit longer. Not a good idea it's just that harness is pricey because I want to get the 034 one
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Just so you can see what I'm working with, and I figured out how to upload pics. Here's one of the coil pack harness,
    Dec 28 2006
    Western Maryland
    That harness is pretty nasty. Replace it as soon as you can.
    The ECM measures the torque pulse between firing events. If the pulse varies significantly between the same firing events over a period of time it gives a misfire code. The change in torque pulse can be caused by a faulty injector, spark plug, coil pack, whatever. You may have a random short that is causing a stuttering that you can feel but it isn't significant enough to give you a misfire code. That doesn't preclude the harness as the the source of your misfiring.
    Replace the harness as soon as possible and go ahead and run a boost pressure test now.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Well I decided she was due for an oil change and while I was under there if found this piece hanging down I believe this part is for the underbelly pan. I currently don't have one but want to get one eventually. But for now so it doesn't drag can I just remove it since I will probably need a new one? Or does it hold anything else up with it?
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Dec 28 2006
    Western Maryland
    Just remove all the busted up pieces then see about replacing the belly pan at your first opportunity.
    Lots of guys just remove them for the convenience. I don't recommend it. The belly pan helps to keep the engine bay a lot cleaner, it protects the wiring, increases gas mileage, reduces noise and lowers the under hood temperatures.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I had read a post that you had input in about how they are actually beneficial. Since I saw you saying that I knew I needed one lol. I would have one but I bought the car without one
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Having issues as well with my coil pack harness, picked up the OEM harness kit on eBay about 70-80$
