Results 1 to 24 of 24
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    Ugh...Coilpacks. Whats the flavor of the month...
    So I am finally down to zero back-up coilpacks in my trunk.
    I have gone through aprox. 8 this year, and i dont even drive the car that much anymore.
    I would just go to the pick n pull every Saturday, and grab as many as I could find. Obviously someone is beating me to the punch! Fukers!
    What is everyone using now a days?
    Bosch fd05 what ever plugs, gtrs.
    And why the F@ck dont we have a solution yet!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    What version are you currently running?
    Here's an old thread from 2009. Clicky click ® I went through a lot of coil packs. Then in '09 I purchased 4 new "D" coil packs which at the time were the latest version for the 1.8T. As far as I know that was the last revision from VAG for retrofitting the 1.8T to address the coil failure issue.
    As I'm sure you know there have been numerous threads for upgrading to coil packs specified for numerous different VAG engines. The most recent being the R8 red top coils.
    For what it's worth I am still running the "D" revisions that I picked up in '09. They worked with my K03 big injector tune and are currently working fine with the F21L. I still carry numerous spares in the trunk but so far (thank goodness) they are collecting dust.
    Jan 08 2010
    CT Shoreline
    Saw mikes post, and yours post within.
    I will try the the revision D's, cause why not! :)
    Many confirmed failures of the R8 packs with higher boost.
    Im gonna start going to the p n pulls earlier and either beat or meet my competitor. Maybe put him in a trunk.
    I dont know what ones I am running (ill go check) but I think F's, but Im pretty sure they all burnt out long ago.
    Aug 26 2005
    If you are still burning up coil packs, maybe consider using a minimum plug gap and reducing the maximum boost your setup is running. 5 psig less boost will go a long way toward stopping the coil packs from over stressing.
    Vorsprung durch Technik
    Veteran Member Three Rings VAGlover's Avatar
    Sep 23 2013
    b6 a4 track rat
    boston
    I've been on a big injector k03s file for about 40 thousand miles/two years. I use ngk* bkr7eix plugs and the latest revision coilpack you can buy through audi. Still chuggin.
    The only time I ever replaced my coils was when I didn't tourque the center nuts on the valve cover enough. Oil seeped into the spark tubes and fried them. This happened prior to flashing my ecu.
    Sent from my VS985 4G using Tapatalk
    Jan 08 2010
    CT Shoreline
    Im at 240,xxx and have gone through a minimum of 30ish coilpacks throughout. At least 15 were junk yard/used ones.
    Yes, higher boost, and larger plug gap stresses them.
    The solution is not less boost and slower car.
    I have had min gaps and max gaps, didnt really pay attention to if max gaps expired earlier.
    The bosch plugs are a stock gap. Ive used many/all plugs in the 240 Ive driven this car. Bosch's hold up the best/no blow out.
    I will just get the revision F's and see.
    I wonder if you buy coilpacks through autozone, if they will keep exchanging them under warranty?
    Thats a though!
    Jan 08 2010
    CT Shoreline
    Wow! Really, why didnt I think of that years ago!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
    I have like20 autozones in 20 miles!
    All of them had tsi and r8 coils in stock. Duralast or valucraft brand, but who cares!
    Just buy 2, keep 1 in the trunk, and 1 in the engine.
    I really feel stupid.
    Aug 26 2005
    Quote Originally Posted by heywier427 View Post
    Thats a though!
    Yeah, however lacking more powerful/durable coil packs, reducing the boost 4 or 5 psig is the only way to get the current version coil packs to last longer.
    Aug 27 2013
    Philly
    FWIW, I grabbed an Advance Auto coil pack and it did NOT solve by coil pack issue. FCP came to the rescue with the R8 coils and I am back to beating the shit out of my 3.0!
    Jan 08 2010
    CT Shoreline
    Im not saying "solve" my coilpack issue by getting the cheap ones, rather they have a lifetime warranty, so just exchange them when they go bad.
    Keep 1 in the engine, one in the trunk. When the engine one goes bad, put the trunk one in. Then go exchange it.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    8 ignition coil replacements in under a year is quite excessive. Taking the used/junk yard coils out of the equation, I would try to figure out if the issue is with the ignition coils, or if there's something else going on to cause the coils to burn out prematurely. Are you getting enough spark (possible cracks in the ignition wire harness)? Are you running rich/lean?
    I've been super happy with the TFSI/R8 ignition coils and using the appropriate spark plugs with the larger gap (BKR7EIX-11). These don't appear to have the design issues that the 1.8T coils have had. Maybe because I'm a bit paranoid, but since I'm using the Iridium spark plugs, I'll change out the ignition coils when I change the plugs. Have been a reliable setup (and maintenance plan) for the past 90k+ miles for me.
    USP CLUB MEMBER #34
    Dec 25 2004
    Earth
    Had a solution a loooooonnnnnggggg time ago! Where you been!
    Search is also useful....
    http://www.audizine.com/forum/showth...?highlight=06e
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Jan 08 2010
    CT Shoreline
    I guess under a rock.
    All 8 were def. used junk yard ones, so they all could have had 100k on them. They were just free.
    I did def. search before I posted, and read your post (as stated above. I called you mike not mik). Have the same problems as seerlah, as far as still blowing. He too is running the bosch plugs, so maybe its those?
    But I know Ive used those and they did not last with the -11 plugs. I think I even posted up a few pictures of how they looked after an oil change interval.
    Maybe it is the car, but other than coilpacks, it runs great. No real issues in 240,xxx (knocking very hard on wood right now!!!) :)
    Going to autozone tonight to pick up tfsi coils.
    Now that my buddy in the parts dept. at vw has moved on, it just hurts spending money on these things.
    Thanks.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Why not just get genuine FSI coils from GAP? I think they are around $15/piece
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Apr 07 2011
    TRT30 at Advanced Auto gets you 30% off. Gotta order online but you can pick up in-store.
    Aug 26 2005
    Thanks.
    An important aspect of running t TFSI coil packs, is that the ECU controls the "Dwell" or time energized per spark event. I believe the time energized is a little to hot for the TFSI coil packs compared to the requirements of the stock original 1.8T coil packs. If the primary current time energized is excessive, the extra power supplied to the coil packs will do nothing except heat up the coil pack primary and secondary circuits. For best reliability, the time energized settings in the ECU needs to be changed by reducing the time energized. This will reduce coil pack failures and won't reduce spark energy, but will allow the coil packs to run cooler, with less stress from high boost and wide plug gaps. "f1torrents" has posted about changing the Dwell/time energized in the ECU software. Duplicating the time energized maps used in B7 ECUs flashed to modified .bin files in our 1.8T ECUs for use with TFSI coil packs would be a place to start.
    Jan 08 2010
    CT Shoreline
    Interesting. I will contact my local tuner, and see if hes willing to play.
    Will send him your above post, as it says alot.
    Thanks.
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    I just had an Advance Auto open up near me. Is this a discount code you enter at check-out?
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Mar 21 2015
    Quote Originally Posted by DPDISXR4Ti View Post
    Yes it is used at checkout, I think it's good till the 16th though. Double check.
    Apr 07 2011
    I've been using that coupon code for a solid 3 years.
    Mar 21 2015
    Sweet, there were some better ones recently that expire the 16th though.
    Apr 07 2011
    Yea, I think there was TRT41 right? $40 off of $100. I won't be happy if they take the TRT30 away, been using that way to often.
    Mar 21 2015
    That's the one, got a new battery for my buddies car on that one.
    Veteran Member Four Rings Jermunji's Avatar
    Jun 11 2013
    2006 Lexus “Landcruiser” LX470| 2001 GTI | 1987 bmw 325is
    The Mines, CO
    I've been running the red tops and around 23 psi no problems. My gap is about .30 I believe.
    "If you don't look back at your car while walking away, you bought the wrong car."- Anonymous
    "Us enthusiasts are numb to cost efficiency, otherwise we'd all be driving FRs or Imprezas"- Atid
