Results 1 to 10 of 10
    Established Member Two Rings TTALMS's Avatar
    Jul 02 2009
    2011 Range Rover
    Dallas, TX
    JHM pulley going in
    At Blair Automotive in Plano, TX getting my JHM pulley and new start button installed.
    JHM linkage w/ USP SS line : test pipes : pulley : intake spacers : tune : 2-pc rotors Ecode shifter : sways : end links : AK : Sport UCAs w/H&R coils & CR-15 AWE Non-res downpipes w/ GMG exhaust : intake tube w/ APR CF intake 034 mounts & inserts Style VFF103s : DEVAL : BFI knob/boot : custom s-wheel : CF inlays
    Account Terminated Four Rings
    Sep 13 2014
    New York
    Horsepower
    Senior Member Two Rings Canadianwraith's Avatar
    Dec 30 2014
    London, Ontario
    What is the advantage of the pulley in hp numbers?
    2009 S5 / Meteor Gray / Fast Intentions / JHM Tune / RS5 Grille / Honeycomb Fogs /20 x 10.5 Niche Targa M129 with 285/30/20 / AWE Filter / 034 Inlet Hose
    Senior Member Two Rings jwr9152's Avatar
    Apr 08 2015
    Pensacola, Florida
    Would love to hear your impressions of the crank. Thinking about doing that as well.
    2011 S5 6 spd 4.2 V8 with APR stage 3 supercharger, APR tune, B&B exhaust, Bilstein PSS10 B16, 034 strut mounts, SPC adjustable control arms, USS sway bars and end links, JHM lightweight flywheel and clutch, Meisterwerk short shifter, 034 transmission mount, Stoptech BBK, carbotech xp12, alu kreuz, 034 intake, apikol differential mount, AWE S-flo filter, cr-15 strut brace, Advanti Hybris 19X9.5, Michelin Sport Cup 2 275/35/19. USP RS5 grill. 034 Motor Mounts
    Jul 02 2009
    2011 Range Rover
    Dallas, TX
    The pulley doesn't add anything to the HP numbers. According to JHM it reduces the rotating mass, which is meant to free up power. There isn't much difference. But it does feel a bit more responsive through the range. Which adds a bit more to my smile as I drive it.
    Apr 08 2015
    Pensacola, Florida
    Anytime you free up weight it's a good thing
    Jul 02 2009
    2011 Range Rover
    Dallas, TX
    ^^ True.
    Aug 19 2008
    US (Al.)
    Did they have to pull the radiator to get access?
    Jul 02 2009
    2011 Range Rover
    Dallas, TX
    Great question. I'm not 100% sure. But I'll ask them.
    May 10 2012
    downingtown, PA
    Quote Originally Posted by SDS View Post
    Quote Originally Posted by TTALMS View Post
    pretty sure at least they put the core support in service mode. there's no other way to get a wrench and socket in there without breaking stuff..
