Results 1 to 26 of 26
    Dec 11 2014
    san diego
    good set of coilovers for RS4??
    I just purchased my B7 RS4. it's all stock minus the miltek exhaust. I'm shopping around for a set of coilovers. what do some of you guys have on yours and how do you like it? how's the handling? I'm not trying to track the car, just daily drive it. also, I'm looking for adjustable coilovers and not too bouncy or too stiff. thanks!!
    Dec 05 2006
    So. Cal.
    Ohlin Motorsports and I like them
    Veteran Member Three Rings Seattle squash's Avatar
    Jan 27 2013
    B7 RS4 + BMW E92 328i (modified a bit more)
    Happy with the bilstein PSS9.
    Senior Member Three Rings sideshowbob's Avatar
    Apr 02 2007
    2007 RS4
    PA
    KW clubsport are great as well
    F80 M3 - Current
    2007 Mugello Blue RS4 - SOLD
    2017 Glacier White SQ5
    *Diamond Stitching/Carbon Inlays/21's*Black Optic +*
    WTB- Clean B5
    Jun 26 2015
    Cortlandt Manor, NY
    Quote Originally Posted by low_qu4ttro View Post
    KW V3... Thats it. Handling is superb and still comfortable
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    +1 for Öhlins
    Dec 11 2014
    san diego
    both look good. how low can you drop the KWs?
    Jun 26 2015
    Cortlandt Manor, NY
    I am at 25.50 GTF
    Senior Member Three Rings Gareth_oau's Avatar
    Mar 13 2011
    Perth Australia
    do the ohlins need a periodic rebuild?
    Jan 14 2009
    Audi's
    Can't go wrong with Ohlins, KW V3 or PSS9's all really nice offerings for the chassis.
    Apr 03 2012
    Raleigh, NC
    I am assuming everyone with Ohlins are talking about Stasis MS. If you can not buy them now are they really relevant to the discussion. Obviously you can buy used.
    Sent from my Galaxy Nexus using Tapatalk
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    Ive ridden on H&Rs, kw v3 clubsports and bilstein(mine). They are all going to ride stiffer then stock, no matter what everyone says. I have never sat in a coilover setup that rode smoother then OEM.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Senior Member Three Rings Striddy's Avatar
    Jul 15 2011
    nothing but memories
    Quote Originally Posted by Gareth_oau View Post
    They will all need to be rebuilt at some time, but yes Ohlins need to be rebuilt.
    Ghost
    Dec 11 2014
    san diego
    is the KW v3 that much better than the V2? also has anyone tried BC racing? they are about 1k cheaper and I hear good reviews.
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    BC Racing is garbage.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Oct 02 2015
    B7 RS4, UrS4
    Boston
    Quote Originally Posted by swesna View Post
    Nope, Check 034 Motorsports. They carry TTX Ohlins, different level entirely than the Stasis kit. Other sellers carry them too, I just cant recall off the top of my head.
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Mar 19 2013
    TTX will be better than any of the other options mentioned, but realistically most people aren't tracking their cars so TTX is likely more than you need. Any higher end damper will require rebuilds. Lower end like ground control "don't require rebuilds" but will only last a certain amount of time before performance gradually falls off. There isn't really any damper that performs at 100% of new for its entire life.
    Now an interesting thing about the TTX for track applications is that the standard setting doesn't allow enough suspension droop on the rears. Bc of this, hard corners can cause the inner rear tire to lift. They are suppose to be correcting this though. There are similar issues for the TTX e46 M3 setups.
    Apr 03 2012
    Raleigh, NC
    Quote Originally Posted by lucidmatt View Post
    My point which was not too clear is most of the ppl that are saying they have Ohlins have Stasis MS which is not an option.
    I know about the TTX Ohlins...but most don't have them bc they close to 6K.
    Dec 11 2014
    san diego
    why are they garbage? input helps. I don't want to by a bad setup
    Oct 02 2015
    B7 RS4, UrS4
    Boston
    Valid point, not many can give firsthand experience with the TTX, though their reputation does precede themselves. Definitely too rich for my blood...
    OP: Another option for the lower budget is the KW H.A.S. which keeps stock DRC. Despite the horror stories a lot of the stock systems still function fine, and if yours does, it may be a viable option.
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    As far as I know BC only has A4/S4 applications and KW only offers the V3 for the B7 RS4. The V3s are great, handle and ride amazing and come with a lifetime warranty.
    Veteran Member Four Rings Chuuey's Avatar
    Mar 06 2010
    E36
    Quote Originally Posted by AvusPdx View Post
    While I respect this opinion and I am sure some will agree; I'm going to have to disagree. Once I had my V3s put on I can honestly say I thought the ride was significantly improved. Perhaps it is just the settings but the car is not only more planted and more supple but it also felt significantly smoother on highway and even on less than desirable road conditions. It was the perfect blend of performance and comfort. They are a great set of coils for daily driving and with some adjustments I am sure they will be formidable in a track setting.
    The OEM suspension certainly did not wow me. It was good but I thought it was even a little harsher than I would have liked, maybe it was just a tired system (I took it off with zero leaks and no signs of significant problems).
    1998 E36 M345 T | 2017 B9 Allroad | 2002 996 GT2
    Previous:
    2001.5 B5 S4 Avant
    2009 B8 S4 6MT
    2008 B7 RS4
    1991 200 20v Avant
    2010 997 C2
    1988 E28 535is Dinan Turbo (RIP)
    2019 B9 A4
    Jan 27 2013
    Quote Originally Posted by Chuuey View Post
    I agree on the ride coils versus stock; once I put my PSS9 to 9 (softest setting), they are just as soft as stock if not softer. However, not all versions/brands have adjustable dampeners which I strongly recommend for the reason of setting them to your own preference.
    Oct 27 2011
    Atlanta, GA
    Agreed! The DRC is hard to beat! But to say "all coilovers are going to make the ride stiffer" is a little harsh. I was happy with the DRC, a little floaty at high speeds, but it handled well in cornering which was the most important thing. It's why I cringe when people replace their DRC with something inferior. If you're going to replace the DRC, please upgrade!
    Jan 15 2010
    Santa Barbara, CA
    I went from Stasis Motorsports to TTX Ohlins, and I don't track the car. I do drive the car hard in canyon/mountain roads. They are significantly more comfortable than any other coilover available for our car, and also handle significantly better. I've had KW V3's, and they aren't anywhere close to the TTX's, since on "soft" (comfortable) settings they are actually soft, and don't handle all that well.
    Yes, they are $6k, but it's worth it. :)
