Results 1 to 10 of 10
    Jan 07 2016
    Upstate NY
    1998 Audi A4 Speaker upgrade
    Can you guys point me in the right direction on upgrading the speakers all the way around? Its the bose set up but the head unit has been swapped to a bare bones JVC. I plan on changing the head unit for something better. But what I want is loud clear speakers. Any website links will be appreciated. I dont know a ton about car audio but i can plug wires lol. Thanks in Advance
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    I highly recommend the speaker setup I went with. The only change (which I have yet to perform) would be a sub upgrade to fix the junk Bose unit.
    It's definitely a lot better in the higher frequencies but needs a good sub to balance out the lows.
    I have no idea what effect your headunit will have on the sound, I still have the stock unit.
    Mar 27 2015
    C6 Avant & B5 A4
    Boston
    Try www.crutchfield.com they are pretty well know in the car audio game, great resources on the site
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Quote Originally Posted by bmos View Post
    +1 for the infinity. They make a great 2 ohm speaker which is what the Bose amp needs.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Jan 07 2016
    Upstate NY
    Anybody know if what amp kinda of amp i should run to use some sort of kicker 4 inch speakers, around 4 ohms?
    Mar 06 2015
    2004 F150
    NOVATO, CA
    For Bose I would think about a five channel amp. It can run the fronts, rears, and a sub with all the crossovers built in.
    I have stock non-bose fronts. In the summer I installed some off-the-shelf kicker 6.5 2-way in the rear deck. I was running them off the dinky little stock amp that ran the stock rear speakers. Then on labor day I scored some Bose rear door panels with some sweet Phoenix Gold 6.5 2-way for half price at the junkyard. I just got around to installing them this weekend with a Jenson 200w max amp that I got off CL for $10 bucks. I wired the rear deck speakers and the rear door speakers in parallel so its getting 75w rms @ 2 ohms full range. It sounds killer. Super clear and crispy with some ok base. Its a good amp, but not great. I think Rockford Fosgate and HiFonics make great amps. Before the Jenson I bought a used old school RF 160.4 for $40 bucks. It sounded way better than the Jensen on those same four speakers. But it quickly fried some transistors. Not Im trying to fix it DIY style. There are lots of forums and opinions about amps out there. You do get what you pay for. And its risky buying used stuff but it was cheap.
    Now I cant wait to get front separates and maybe a sub eventually. Ill probably get 5 1/4 Kenwood seperates from Crutchfield for the front. Something in the 100 to 150 watt/dollar range. I read somewhere they can be installed with a little re-work.
    Mar 06 2015
    2004 F150
    NOVATO, CA
    That wheel well is pretty cool. Cool to see all the details in one place.
    In some cases a nice aftermarket HU will sound better because the low level outputs are better matched for amplifiers impedance and voltage. Some people get ground loop problems and alternator whine when things are not grounded well. I tapped into the low level outputs from the stock HU and it sounds fine with my amp. I wouldn't mind a double din DVD with preset EQs.
    Apr 29 2014
    Maine
    Quote Originally Posted by griffdra View Post
    Yeah I love Wheelwell, it's been great seeing them grow over this past year.
    I would love to redo the whole system with new speakers, amp(s), wires, and h/u but I don't want to do all that interior work.
    I actually have ground loop and alternator noise with the stock headunit as someone botched all the headunit wiring at some point before I bought it.
    It's on my to-do list.
    Eventually I will but the setup I'm running now is great for anything but hip-hop/edm (where the Bose EQ really... blows).
    Veteran Member Three Rings xthealienatorx's Avatar
    Mar 01 2013
    10 Avant, 03 Superduty 6.0 zf6, 13 Grand Cherokee Overland Hemi
    Louisville, Kentucky
    Ive got a pioneer 2500 touch screen bluetooth headunit. A good quality head unit is very important. For speakers i have stock front doors, and deck, jbl gto 528's in the rear doors. (jbl and infinity would be my two choices as they work great with the factory amp, jbl is a little more acoustic over the infinity) and a alpine type r 12 in the trunk. i cant get the speakers to distort other than the sub as i have only like 150w going to it.
    If i were to go all out, id do jbl gto 509c and 609c. 509 in front, and 609 in the rear. And possibly deck, or just higher range subs. Then the 4channel gto amp, (speakers have good crossovers with them) and a 12inch type r on the 1000watt rms jbl amp.
    Jan 07 2016
    Upstate NY
    Thanks guys in going to look into your suggestions. I just cant wait for the winter to be over to build her
