Results 1 to 21 of 21
    Senior Member Three Rings Jey4's Avatar
    Apr 02 2013
    West Haverstraw/NY
    Is my HPFP Damaged?
    Finally got around to changing the cam follower. Looked as if it was replaced by the previous owner at some point. My question is the wear on the hpfp. Is this something I should be worried about? Your inputs is appreciated.. Thanks.
    -Jey
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Yeah, that thing is worn. Replace it or you may be able to upgrade internals... (Apr, jhm, etc.)
    I would also inspect your intake cam.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    How is your follower looks?
    Sent from my SM-G900T using Tapatalk
    Apr 02 2013
    West Haverstraw/NY
    I was considering upgrading the internals vs just replacing it. Intake cam was lightly scored. My assumption is the last cam follower was blown thru because of the wear and replaced at some point. The black coating was light worn on the follower I replaced.
    Sent from my LG-V500 using Tapatalk
    -Jey
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Not to thread jack but what are the signs of a cam follower going bad? Ive read its not as common in the 08's, true or not?
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by adam044 View Post
    Theoretically because 08s have the revision B cam. You won't be covered under the extended warranty, so check and replace the cam follower ASAP, if it hasn't been done.
    Mar 24 2013
    Oakdale, CT
    While it's true that '08s have the rev B cam and don't fall under the extended wartanty, they are just as likely to burn through the follower.
    -Adam
    Veteran Member Three Rings szaer's Avatar
    Mar 14 2013
    Greater Toronto Area
    This. I was stupid and never checked, engine completely ruined when I had my b7. Luckily I was an 07 and covered under warranty (completely replaced engine). All 08's please check your followers, you're definitely not immune.
    2014 Lava Grey S5
    Nov 30 2015
    New York
    How many miles did you have when you took a look at it ?
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    100% damaged....Very weird wear as well. If your cam follower has asymmetrical wear on it, easy way to tell if your HPFP is bad.
    If you think your PO did that, replace cam follower, HPFP, and intake cam immediately, along with a full cleaning of your oil system (dropping the pan + cleaning out the pickup tube).
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Apr 02 2013
    West Haverstraw/NY
    Quote Originally Posted by bfunk1414 View Post
    Car has 120k
    Sent from my Nexus 6 using Tapatalk
    -Jey
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Good time to grab our HPFP Upgrade: https://jhmotorsports.com/shop/catal...si-p-2653.html
    Apr 02 2013
    West Haverstraw/NY
    Quote Originally Posted by BenMTL View Post
    The cam follower looked to be worn symmetrical but to my judgment it was replaced at some point so hard to say without knowing how long it was in there for. I bought the car 5,000 miles ago.
    -Jey
    Account Terminated Four Rings
    Oct 15 2013
    that pump is missing the "button". all of the HPFP manufacturers would call this pump a loss. i'd change it.
    Jun 27 2011
    That wear can only happen if the follower has worn through at some point. Replace the pump for sure and inspect the cam lobes for scoring and wear. The thing is once they wear down some they start burning through followers super fast.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Dec 27 2015
    Chantilly, VA
    How fast does it wear
    If the hpfp hit the lobe and you only replace the follower how fast will it burn through the new follower? Every 5k 10k? dealer wanted 3k to do it. Car is worth 2k with 175k miles.
    Oct 31 2014
    NH
    My dads 06 has never had this replaced. He's got 120k on his. At least to my knowledge it hasn't been replaced. Is that normal?
    Apr 02 2013
    West Haverstraw/NY
    Thanks for the input everyone. I ended up finding a barely used pump with upgraded JHM internals.
    -Jey
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Quote Originally Posted by elester12 View Post
    That will determine on your oil level and how much damage there is. I can GUARANTEE there are a ton of people out there running new cam followers with slightly scored camshafts and pumps with tips that are a bit worn. The car will still run--there are lots of stories with people who ran the car forever with blown followers and very scored cams and tips on the HPFP that were well gonzo before the car started throwing codes and running poorly.
    I'm sure there are people who look at a 2-4K repair and or all that time and put in a $20-25 cam follower every 3-5k and call it a day. By that time those shavings and shards from the blown cam are down in the oil pan where they cant come back up.
    Senior Member Two Rings Gotpsi2008's Avatar
    Mar 24 2015
    YFZ 450, Beer Fridge
    Sebago, Maine
    I did the follower on my 08 at 82,xxx, it had slight pitting, and I just checked it at 98,xxx and it has slight wear, I'm probably just going to change it every 25,000 miles just to be safe
    Jun 27 2011
    My follower now has 25k on it since replacing my cam. I've actually been meaning to change it...
    -CP
    2017 Q7 3.0t
