Results 1 to 19 of 19
    Aug 06 2012
    san diego
    Super bright LED reverse lights installed
    Much brighter, cleaner, will last longer, just overall much much better.
    Senior Member Two Rings JohnnyUtah787's Avatar
    Oct 03 2015
    Illinois
    Any details on the exact part? Tips on install? Picture of the lights from behind?
    2015 Audi S3 - Glacier White, 19" Performance Package, B&O Sound System, LED Lighting Package, Black Optics grille, Black optics fog grilles, Black powder coated OEM exhuast tips, Satin black 19x8 ET45 Neuspeed RSe10 wheels with Continental ContiSportContact 5P tires (summer set-up), OEM 19x8 ET49 double 5-spoke wheels with Pirelli Winter Sottozero 3 tires (winter set-up), 15 mm ECS spacers all around, Emanuelle Design springs, 034 Motorsport dogbone mount insert
    Aug 06 2012
    san diego
    Quote Originally Posted by JohnnyUtah787 View Post
    All you need is a flat head to wedge open the gray fabric cover. pinch the plastic clips that hold the harness. push in and twist the old bulb out. push in and twist the new bulb in. push harnes back into place and close the fabric cover. took 30 seconds.
    here is the link: http://deautokey.com/product/2015-au...e-reverse-leds
    this is a terrible image but here it is from the rear. stocks vs the leds:
    this image does not really show them well but oh well im too lazy to go back out and snap more
    Oct 03 2015
    Illinois
    Quote Originally Posted by markn1689 View Post
    Image is perfect for what I was looking for, thanks for doing that. Any idea if it's safe to assume these will also work on an S3?
    Aug 06 2012
    san diego
    umm that IS an s3...
    left is stock and right is led
    Oct 03 2015
    Illinois
    Haha sorry, couldn't quite tell from the picture. Just wanted to be sure since the website says "A3" specifically. Thanks again for the info.
    Senior Member Two Rings eastbayrae's Avatar
    Jul 23 2014
    2014 Audi S5 Cab, Imola Yellow '16 SQ5
    Raccoon City
    I wonder if those would work in my SQ5
    Marine math: 1 shot = 12 kills
    Aug 06 2012
    san diego
    Quote Originally Posted by reyoasian View Post
    How's the visibility in reverse at night?
    I had this done on my previous cars with several different LED bulbs; they were crisp as hell when you looked at them but lumens output and visibility weren't as good as OEM halogens (but that was when LEDs weren't as mature as they are now...)
    visibility is better but its not quite as good as I thought it might be. better than stock though
    Jan 13 2016
    Atlanta, GA
    Thanks for the pictures and info about how you installed it! Will order a pair.
    Stage 2 Banner Advertiser Four Rings deAutoLED.com's Avatar
    Feb 13 2015
    US
    Thanks for the review - this works in all models with the bax9s reverse:
    deAutoLED.com
    Facebook.com/deAutoKey
    Instagram.com/deAutoLED
    Lifetime Warranty & Support | Free Shipping within the US | LEDs Tested to work and look good in your car | Customer Service is our #1 Priority - We care what you install in your car!
    Established Member Two Rings Metrshr's Avatar
    Oct 31 2012
    16 Q5, 04 MSM, 07 MX-5 PRHT
    Goffstown, NH
    So when you mention harness, do you have to remove it from the compartment to install the LED bulb?
    Got a pic of said harness? I got in my LEDs and want to install when I get home.
    TIA!
    2016 S3 Prestige|Sepang Blue|Black Optics|S. Seats|
    Aug 06 2012
    san diego
    Quote Originally Posted by Metrshr View Post
    TIA!
    check out page 2 of this thread: http://www.audiworld.com/forums/audi...2894402/page2/
    i have pics of the install. you do not need to remove any harness- just remove the fuzzy grey cover
    Oct 31 2012
    Goffstown, NH
    Thanks Mark!
    Aug 06 2012
    san diego
    Thanks Mark!
    actually just remove the fuzzy cover then clip the harness out- 2 clips to remove.
    Feb 13 2015
    US
    Good info, thank you for sharing.
    deAutoLED.com
    Senior Member Two Rings 16s3pang's Avatar
    May 07 2016
    07 Mazda MX-5 PRHT
    Goffstown, NH
    Did you ever figure out what LED fits for the rear fog?
    |2016 RS7|
    |Sepang|Dynamic Pkg|B&O|Comfort Seats|Aluminum Atlas Inlays|Cold Weather Pkg|Milltek non-res exhaust|Roc-Euro intake|034 Motorsport Drivetrain Inserts|
    Aug 06 2012
    san diego
    Quote Originally Posted by 16s3pang View Post
    yes.
    here:
    http://www.audizine.com/forum/showth...led-Error-Free!
    Nov 23 2016
    NV
    I went a different route than you. I still visit Golf Mk7 forums (I owned a Golf 7R and saw @DeAutoLED released a newer oversized and "brighter" LED bulb for the Mk7 European LED tail lights (see http://www.golfmk7.com/forums/showthread.php?t=27544). These oversized bulbs uses a BaY9s base which does not fit North American A3/S3 8V models that uses a BaX9s base. So I simply asked if they could also make me am oversized bulb but for it in a BaX9s with their Mk7 group buy. 2 weeks later I received the units and here are my observations and experience:
    1. The bulb is indeed oversized and just a smidge to big to fit our housings
    2. This is NOT for everybody but I enlarged the opening using a soldering iron method to melt the plastic. I didn't use a rotary tool to grind the housing because I hate fine plastic shavings stuck in the light housing.
    3. This new bulb does seem to have more output than the factory incandescent reverse bulb. I didn't have a light meter to measure output, just pics of the spread on back of garage door.
    4. From outside in the dark or daylight, the color is very bright white vs. factory yellow.
    5. From inside the cabin, it does seem to have more light output when looking at the MMI screen during backup. However, if you're looking for a white output on the screen, it's NOT going to be there. That's because the LED bulb white output is mixed with the A3/S3 strong red LED tail lamps. I'm sure it's still very white white from the outside but inside the cabin, it's a mishmash of red/white on that screen.
    Overall, I think this is a good upgrade; it's bright and error free. From the outside, people will see a bright white reverse light. Just don't expect it to look that crisp white on the MMI screen for reverse.
    Feb 13 2015
    US
    Quote Originally Posted by BodegaBay View Post
    Thank you ! This is a custom made LED - if anyone is interested they would need to email [email protected]
    deAutoLED.com
