Originally Posted by
VR6OhMy
Don't worry about individual measuring blocks or trying to interpret things. Just read the fault codes for now and report back what DTC's are stored and then we can help you make an educated guess as to what the problem(s) may be.
Yes just scan it and read the fault codes. Take the most logical approach you can. We will check for spark, fuel, vacuum, etc... I just don't like seeing people change stuff like 02 sensors if they don't actually check to see if they are working or not. People change the dumbest stuff because they got a code for it. Think of it this way....If you get a code for an 02 sensor saying "bank 1 system too lean" some people go out and change the 02 sensor, not realizing that it is reporting a problem, and its NOT the problem. Yeah the 02 sensors fail, but that's not what that code is telling you. Lean means there is unmetered air getting into the engine somewhere after the MAF (sometimes it is actually a dirty MAF and its not reading all the air that is passing through). The 02 sensors just trim the fuel up or down to help return to the "stoichiometric" ratio of 14.7:1 air to fuel ratio. The ECU will throw a CEL once the percent (as metered by the long term fuel trims) goes out of the range that the computer sees as optimal. In the case of a crank, no start situation... Spark or fuel would be the first direction...monitoring the measuring blocks would help you diagnose a bad coil pack, or if the misfires are consistent to one bank, then the timing adjusters could be at fault and then you might have to pull the engine to fix. Diagnosing the problem using VCDS will help you so you know what direction to go. Don't just pull the engine because someone online says to or because the mechanic says to. Use VCDS to Validate the codes and see what is causing the problem.
