Results 1 to 10 of 10
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    K04 Pre-turbo pressure readings
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    what's the significance? that the exhaust pressure isn't 100% being converted into intake pressure doesn't surprise me...
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by james 408 View Post
    There's a few things I'm interested in, main thing is to have some data I can use to compare to other turbo's with.
    Oct 27 2011
    TOYS
    Philly Suburbs
    The significance is understanding how restrictive the exhaust housing is for the amount of flow your trying to force through the turbine. The data is certainly more useful if you can actually adjust the turbine housing a/r.
    Jan 11 2007
    Salt Lake City, Utah
    Thumbs up for the data.
    Registered User Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Portlandish
    The significance is twofold.
    First, the stock exhaust valvetrain will reach its limits at about 60psi of pre-turbine back-pressures. If you exceed the limits, the valve springs will not be able to hold the valves closed against that pressure behind them. This leads to a condition called "valve float" which wrecks the combustion cycle and immediately kills power.
    Second, higher back-pressures impact the ignition timing advance. The pressurized exhaust gases will contaminate the intake cycle, raising the air/fuel mixture temperatures and leading to premature detonation.
    These two considerations make pre-turbine back-pressures a critical metric for hybrid turbo design. And that's why we monitor them closely in all our testing.
    Sep 11 2009
    NE
    Thanks for measurements.
    Jan 20 2014
    Woonsocket
    Flyboy, mind sharing your hardware setup for logging the exhaust pressure? I am running oddball K03 hybrids and it might be useful for me to keep an eye on drive pressure when I turn boost up. I have been considering buying a Zeitronix Wideband controller with aux inputs and pulling exhaust pressure from the sai port on the passenger side head.
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by Nichtknicken View Post
    It looks about like this. I've since replaced the long rubber hose with a pressure snubber and a much shorter length of tubing, but the basic concept is the same.
    Jan 20 2014
    Woonsocket
    Thank you. I somehow missed that looking around your site. Much appreciation for putting up your pressure logs, should make a nice point of reference for me in the future.
