Results 1 to 40 of 48
    Established Member Two Rings hamz01's Avatar
    Aug 29 2014
    Chicago
    Did the StopTech 6 piston/380mm big brake kit install last night
    380mm/15in rotors
    Gotta wash off the rust inhibitor on the rotors.
    Saving 2.4 lbs of unsprung, rotational mass per side.
    Saving 6 lbs of unsprung weight per side.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Nice! Planning some track days?
    -cW
    Sent from my SM-G900V using Tapatalk
    2023 X3 M40i Alpine White
    Apr 11 2012
    ooohhhh... very nice!
    how much clearance do you think you have between the highest point on the caliper and the inside of the wheel barrel? 1-3mm?
    Nov 13 2009
    the OC, SOCAL
    cool.
    so what was the cost of the kit?
    did it also come with the rear ss brake lines?
    whats the model number for the kit you got?
    as I think there are two version or even four.
    is there a different color for it?
    Aug 29 2014
    Chicago
    Hundreds.
    -cW
    Aug 29 2014
    Chicago
    Quote Originally Posted by will13k7 View Post
    There is probably over 10mm of clearance. I'll take a closer look when I can and throw up a picture.
    Aug 29 2014
    Chicago
    Quote Originally Posted by 949 View Post
    cool.
    Kit can come with 4 or 6 piston caliper and 355 or 380mm rotor. My kit is 83.896.6800.51 from Excelerate Performance. I'd shoot them an email asking about colors/pricing. They are very helpful with great customer service.
    Aug 09 2011
    Richmond
    Very nice! Are spacers required?
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by hamz01 View Post
    oh thanks.
    i was just curious what people were actually getting them for.
    Aug 29 2014
    Chicago
    Quote Originally Posted by robertsonsylee View Post
    I run 15mm spacers but I put the wheel on without to see about clearance and it's fine.
    Aug 29 2014
    Chicago
    Quote Originally Posted by reyoasian View Post
    Do they have anything for the rear?
    I have not seen any calipers for the rear, mostly due to our electronic parking brake I think. I would love to at least have matching rear rotors and I may go the route of adamsrotors.com for their pattern-matching rear rotors.
    Jun 19 2011
    2013 VW Golf R
    long island
    I notice when you weight the caliper, you also have the splash shield on there. Does the new kit come with a larger splash shield or you just don't put one on?
    2000 Audi A4 Koni coil over,Flik wheels, MTX sound system.
    2013 VW Golf R,UM Stage 2 tune,CTS intake and heat shield,Autotech HPFP,Sigma 6 speed short shifter,neuspeed front mount intercooler and delete bracket,APR turbo back exhaust with cat,BSH throttle pipe,CTS turbo pipe,US Millwork tow hook license plate holder,H&R lowering springs
    2016 Audi S3 floret silver,LED, Sports seats, resonator delete, stock location K&N filter, posi quit front break pads
    Senior Member Three Rings roadrunner_oz's Avatar
    Mar 30 2015
    Australia
    Nice!
    About to upgrade my front rotors. How difficult is it to release the carrier bolts as at 200Nm?
    S3 Sedan - Glacier White SSP2 Black Optics trim. UniTronic S1+ & DSG Flash. Neuspeed RSe10. GFB DV+
    Aug 06 2012
    san diego
    __
    Jun 19 2011
    2013 VW Golf R
    long island
    Do you know if the factory 18" wheels will fit over these, looking to still use them for the winter.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Any details on the chair(/crawler?)? I could use one to replace my upside-down milk crate.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Aug 29 2014
    Chicago
    Quote Originally Posted by lamchop View Post
    New kit doesn't come with new shield. I'm currently looking into whether or not I should modify the existing one to use but for now it is just off the car.
    Aug 29 2014
    Chicago
    Quote Originally Posted by roadrunner_oz View Post
    Nice!
    It's easy to release those bolts. Make sure the entire front of the car is up and turn the wheels to the side you're working on. Use a breaker bar with a cheater pipe and they loosen no problem.
    I didn't know they were 200nm (147ftlbs) and I only torqued them back to 108nm (80ftlbs). Gotta tighten those up I guess. Where do you find that torque requirement, for future reference?
    - - - Updated - - -
    I am almost certain the factory 18s do not fit over the 380mm version. They work on the 355mm version. Some aftermarket 18s probably do clear the 380s though.
    Jun 19 2011
    2013 VW Golf R
    long island
    Thanks
    Aug 29 2014
    Chicago
    Quote Originally Posted by King_ View Post
    Yeah I love the thing. It's this: Omega 91000 Black 40" Foldable Z Creeper
    Sits kinda high for getting under the car so I also have this: Mechanic's Folding Ground Pad
    Aug 29 2014
    Chicago
    Here are some up close shots of caliper clearance. Looks like over 5mm on top and side.
    Aug 06 2012
    san diego
    damn dude that is tight, i feel like a small rock could get lodged in there and cause some damage.
    i like it the stoptechs though. these would not be good with my weekly inside and out wheel cleaning sesions. with the stock brakes im able to fit my whole hand between to clean the inside behind the caliper
    btw its time to clean your wheels
    Nov 13 2009
    the OC, SOCAL
    did u use a tool or a buddy to bleed the brake?
    Mar 30 2015
    Australia
    - - - Updated - - -
    Thanks, I'll give it a try. I downloaded all the repair & maintenance docs from ElsaWin. I'll dropbox the link to my brake repair file here: https://www.dropbox.com/s/s6qzgxxt6s...ystem.pdf?dl=0
    Carrier bolts front are 200Nm & bolts must not be re-used. Rear is 90Nm with an extra 90 deg turn & bolts are not to be re-used.
    Aug 29 2014
    Chicago
    Quote Originally Posted by markn1689 View Post
    Tolerances that close are considered acceptable. I am also a big cleanliness enthusiast however it is winter here so it will not be wheel cleaning time for at least 3 more months.
    - - - Updated - - -
    Motive Power Bleeder
    Aug 29 2014
    Chicago
    Thanks for the link; much appreciated.
    StopTech doesn't supply new carrier bolts with their kit and states in the instructions to reuse them so hmmmm.
    Mar 30 2015
    Australia
    I just ordered new bolts as the Audi instructions say not to re-use ($5 each).
    When I was trying to source the bolts, one dealer said they don't replace them while the other insisted their workshop always replace them. IIRC high torque bolts such as these weaken each time they are cycled.... others may know more info?
    Aug 29 2014
    Chicago
    Good to know. I have actually removed the carrier bolts another time before, so I'll swap them out with new ones. Just ordered them from ECS along with new rear carrier bolts as I have to remove those to swap in the new matching rear rotors I just ordered from Adam's Rotors.
    Thanks for the knowledge!
    Mar 30 2015
    Australia
    Note that to remove the rear carrier you need a triple square socket. God knows why Audi would use that on a high torque bolt?!?!
    Aug 29 2014
    Chicago
    Yep just bought a set. Another thing to throw in the tool bag haha.
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Awesome install and review. You are going to love this kit! We have these on sale right now too if anyone is interested in adding one of these to their S3 or Golf R.
    Cheers!
    Greg
    Aug 29 2014
    Chicago
    Quote Originally Posted by Excelerate Rep View Post
    Cheers!
    Greg
    I already do but I'm going to be positively head over heals come track season!
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    No more Porsche's sucking up to your bumper in the braking zones.
    2016 Monsoon S3
    My slow build link - Onequick4door
    Feb 14 2014
    Audi's
    Branford, CT
    Be sure to let us know how you like it!
    Greg
    Aug 29 2014
    Chicago
    Quote Originally Posted by onequick4door View Post
    Haha yes. I had a Cayman owner tell me exactly that at Road America in October. I was losing so much time in braking zones with stock setup.
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    Did you find out whether or not the shield was needed? I just got the 355mm kit so I'm curious if I'll need it or not.
    Any chance you can re-add that file to Dropbox? Would love to check it out.
    Are these the bolts I should order? Assuming 2 per caliper so 4 bolts front, 4 bolts rear. Correct? Just want to double check.
    Front: https://www.ecstuning.com/Audi-8V_S3...ront/ES471856/
    Rear: https://www.ecstuning.com/Audi-8V_S3...ear/ES1894565/
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Aug 29 2014
    Chicago
    Quote Originally Posted by phillyquattro View Post
    I am still without the shield and I don't think that will change. I don't know of any option other than cutting the stock shields so they don't interfere with the rotors which will then leave you with an even smaller shield that won't cover all of the disk. Not to mention I want maximum airflow around the rotors.
    Here's the repair doc: https://www.dropbox.com/s/2acka5afnk...ystem.pdf?dl=0
    Those are the correct bolts. You shouldn't need to interact with the rear carrier bolts ever because the rear carrier doesn't need to be removed to replace the rotor.
    Aug 29 2014
    Chicago
    Here's a link to my post about the matching rear rotors I got from Adam's Rotors to compliment the BBK.
    San Francisco, CA
    Thanks for the follow up info and the PDF! Super helpful!
    2019 GT3 Touring
    IG: brandongray
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    hamz or anyone else running the stoptechs or other big brake kit-
    Are you running around with your brake warning(little red light on the tach side) on or did you cut the wire sensor from the stock pad and splice the end together.
    I just put on the ST Trophys and have the red warning light, which I expected, but didn't know if my work around would actually work?
    2016 Monsoon S3
