Results 1 to 19 of 19
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    Oil/filter change using extractor...
    My fluid extractor arrived a few days early, along with OEM filters. Therefore, I performed the 10K service on my allroad last night. After figuring out how to connect and use the extractor, the complete process took me about 25mins. Had I fired up the compressor and used the pneumatic portion, I'm certain, the process would have been much faster. Aside from manually pumping the extractor every 5mins to produce vacuum, I have no complaints! The process was painless and very mess-FREE.
    Sep 09 2010
    Destin, FL
    You do know, you could have posted this on any of these already existing threads right?!?!
    http://www.audizine.com/search/index....y=0&sa=Search
    Oct 10 2012
    Zionsville and Saint John IN
    Lol, this is true. Props to the op for doing it himself and saving money.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by richardm0025 View Post
    im excited to do my first audi oil change with extractor lol
    i already got the extractor and filter. only thing to do is run to oreillys for the oil
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Oct 10 2012
    Quote Originally Posted by JeriQo View Post
    I still do it from under. I have an oil extractor that I use on my dads sailboat. I tried it with my b8 and it worked but couldn't suck out everything compared to draining it out.
    Mar 11 2011
    2014%20VW%20GTI%20Autobahn%20DSG
    Conway, AR
    Brave soul. As someone with a replaced lower drain pan, due to DEALER error, I'll still stick with extraction...
    Oct 10 2012
    Quote Originally Posted by PDong View Post
    That's why I do not take my car to the dealer... Lol. Changed it close to 15 times without a problem.
    Feb 03 2010
    Pittston, pa
    can you use the extractor on all Audis
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    Quote Originally Posted by NEPA A8 View Post
    You can use an extractor or anything that has an oil dipstick.
    I typically switch between extracting and doing from below ever other oil change since I change my oil every 5000 miles. If the filter was on the bottom, I wouldn't even bother with extracting.
    2024 RS3 Kemora Gray
    Jun 26 2013
    For some reason i cannot remove more than half the oil from my engine using my Pella extractor...no luck for me, have to do it from underneath.
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    Quote Originally Posted by deadend9009 View Post
    How are you measuring what you've extracted? The Pella works fine for me with 3 extractions so far. I'm guessing about .5L is left in the filter and I get over 4L out. Perhaps you are pushing the tube in too far and it's curling?
    2011 A4 Avant
    Established Member Two Rings AOW162435's Avatar
    Jul 15 2013
    Ellicott City, MD
    I've always changed the oil on all of my cars and find the A4 to be rediculously easy to do. Zero mess draining it properly from the pan.
    Dealers use the extraction method because it's easier for them....
    Andreas
    2014 Audi A4, Monsoon Gray / Black
    2002 Toyota 4Runner, Dorado Gold
    2001 Toyota 4Runner, Dorado Gold, 575,XXX 1-owner miles :)
    1998 Toyota 4Runner, Oxidized, 5-speed
    1995 Porsche 993, Polar Silver
    Aug 10 2015
    Orange County
    Are you making sure the extractor tube is at the bottom of the pan? My extractor pulls out slightly less than 5 liters so I'm pretty much extracting the most that I can.
    Jul 08 2015
    Quote Originally Posted by AOW162435 View Post
    Andreas
    and they expect me to cough up 470 bucks for a 15k service?
    lol they can get to ass kissin
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    I don't like the extractor method either my buddy across from me has an Avant too and i told home he could have mine because I don't see the point in pumping the entire time when I can just do it from underneath quicker. Tried multiple size lines and various depths and,still get the same results.
    Senior Member Two Rings eirebob's Avatar
    Apr 13 2010
    santa rosa ca
    Had this problem initially, until I remembered someone's recommendation to open the fill cap ... no problems since.
    2009 A4 Quattro, Manual, Prem Plus, Sport Package
    Mods: APR Stage II, Stratmosphere short shifter, Alu Kreuz, Tips, Tint, 034 Turbo hose, Cocomats. EC Intercooler pipe, hose kit. RS 5 pedals. Apikol rear diff kit. Vag.com mods. Stoptech slotted rotors, Akebono pads. Interior LEDs, BFI heavyweight knob, CF trim. BC BR coils. P3 Guage. ECS SS brake lines, 10/15 spacers. CR 15 brace. USP HFC.
    Jul 08 2015
    Quote Originally Posted by eirebob View Post
    yep. gotta let some air in.
    Mar 11 2011
    Conway, AR
    Dealers use the extraction method because there's a service bulletin to do so.
    The pan has a threaded insert that's welded into place. It's very easy to strip and it cannot be re-threaded.
    It's a $700 repair.
    Senior Member Two Rings Fox Fader's Avatar
    Nov 24 2014
    Columbus, GA
    I do mine the old fashion way. Maybe once I see or use an extractor I may change my mind about this.
    10 A4 quattro PP 18" Sport Package 6 spd manual 60k
    SOLD! :(
    10 Ford GT 401a 5sp 17k miles
    11 KLR 650
    07 Tuono Factory
    03 F150 STX Lightning replica
    11 Kia Sorento SX (wife's)
    Slammin Tunes
