Results 1 to 7 of 7
    Dec 05 2015
    Chicago, IL
    Unhappy Rev engine, let off gas, scraping/grinding noise -- wtf?
    Hey, so I'm finally getting ready to do some performance upgrades on my 2012 A7 3.0t, but I noticed some strange noises last night.
    I rev the engine in neutral (with the car stationary) and let off the gas... as the RPMs come down, the car makes a strange scraping/grinding sound at two specific RPM ranges: ~3500 to 3200 and ~1500 to 1200. The noise is louder with the door open and seems to be coming from the driver's side, although I can't pinpoint the location exactly. It happens every time I rev the engine and let off the gas. And ONLY when I'm off the gas.
    Any idea of what might be going on here?
    Aug 26 2013
    Video of it?
    Dec 05 2015
    Chicago, IL
    Sound is most noticeable from 0:05 to 0:06 as engine speed drops from 1500rpm to 1200rpm. It does this at the exact same rev range EVERY time I rev the engine and let of the gas.
    Dec 05 2015
    Chicago, IL
    Another note: it gets louder and more noticeable when the engine is fully warm... It doesn't really make any noise if I rev it over 1500rpm when it's cold/only slightly warm.
    Dec 05 2015
    Chicago, IL
    It seems to be a vibration from below the vehicle on the mid/rear driver's side. When I hold the car at 1400rpms, there is a constant vibration noise from that area. You can hear the sound from 0:05 to 0:07 on this video.
    In the video it sound more like a "grind," but it person it sounds more like a "vibration."
    Maybe a heat shield rattling against the exhaust?
    Senior Member Three Rings ///M Traitor's Avatar
    Feb 05 2013
    It's hard to tell from the video, but I'd bet it's something on the exhaust system that is rattling. Like a heat-shield that is loose, or something internal to the Cats. You'll probably need to get the car up on a lift to properly diagnose... The engine vibrations at specific RPMs can cause harmonics that amplify the vibration of attached components.
    Dec 05 2015
    Chicago, IL
    Quote Originally Posted by ///M Traitor View Post
    Yeah, that's what I'm thinking too. I plan on having the AWE touring exhaust installed on it next week, along with some other stuff.
    Is it worth taking this to the dealership -- 1 hr drive each way and a pain in the ass to find the time to get out there -- to look at it, or just mention it to my mechanic when he installs the new exhaust system?
