Results 1 to 24 of 24
    Jun 07 2013
    D.C.
    Cool I found Engine Carbon Cleaning in the DMV
    I was driving in D.C. and came across a hydrogen-Oxygen Engine Carbon Cleaning location.
    It is on Bladensburg Rd NE at the BP gas station across from the Denny's.
    What caught my attention was about 5 high end cars and 10 motorcycles lined up.
    I pulled over since I needed gas and inquired about the process. They seem knowledgeable about carbon cleaning and also they let me check out the generator machine.
    Best of all the price is $149.00 way better than 1400 that Audi wanted to charge me.
    People who had gotten their cars done appeared happy and several told me this was their second car to get the process done. (mostly cops from the station up the street)
    Don't have the telephone number handy left the flyer in the car but will pass it along when I get the number handy.
    Glad to see someone in the DMV stepping up as this is a game changer.
    Veteran Member Three Rings PEM's Avatar
    Jul 17 2014
    NoVA
    In! Nice find
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Veteran Member Four Rings i1overice's Avatar
    May 09 2013
    Loads of junk.
    Northern Virginia
    Edit: I read about this on the 5 forums.
    I think there are some dyno sheets out now but no before or after pics.
    Current - 2017 Honda Civic EX-T
    Sold - 2010 Ibis White S5
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    How does their machine clean the valves?
    For $149 that sounds like a spray cleaning like the BG induction service which doesn't do anything for the FSI carbon buildup that is already present after 30K to 50K miles. The only way to really clean the intake valves and ports of a FSI engine after the carbon has built up is to take the intake manifold off and start cleaning.
    I'd like to see the before and after results as well. Guessing they cant get them, because the manifold isnt coming off to do the job. Options are always good though. We offer a walnut blasting system which is the best I've seen hands down. It is $499 for a 4 Cylinder, $599 for 6, and $699 for 8 .
    Dec 18 2014
    DMV
    Quote Originally Posted by ed@4induktion View Post
    Why can't you do it for free? *insert whining here*
    Sold: 15 S4, 16 Tornado Gray S6, 16 Glacier White RS7, 18 White Q5
    Current: Black SQ5, Black V10 R8
    Next: Gemera
    Veteran Member Four Rings csullivan's Avatar
    May 10 2010
    1997 Jeep Wrangler TJ
    Charleston, SC
    That V8 pricing is the best I've seen from a full shop, not too shabby.
    And thank you for not simply doubling the 4cyl rate, which I've seen and is silly.
    May 10 2010
    Charleston, SC
    Oh, and I'd volunteer as a guinea pig, but I JUST had mine cleaned. But we should pull someone's IM, get some befores, all kick in, and get an after. Lets see if this really works. I'd kick in a couple bucks and a heated garage for the inspections.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Wow ed, that price is stellar!
    Quote Originally Posted by JimmyBones View Post
    this. its not the type of carbon cleaning these direct injected audis need.
    Veteran Member Four Rings jamerican1's Avatar
    Nov 15 2009
    2008 A4 S-Line Titanium TQM, 2000 A4 1.8tqm, 1993 Audi 90S(sold)
    VA
    This is relevant to my interests
    Unf*ckwithable
    Veteran Member Four Rings kiku's Avatar
    Jul 11 2013
    2001 Audi S4
    Pittsburgh, PA
    Audi woes
    2008 997.1 GT3
    2015 Allroad
    2014 Ram 3500 Dually (the double wide)
    2014 Phantom Black RS7 w/ APR Stage 1 Tune (sold - farewall fast rs)
    2001 B5 S4 (the track slut)
    2013 Q7 S-Line (sold)
    Jun 07 2013
    D.C.
    Went back to them and asked if this was like the BG induction service which is good had it done on my previous car a x5 4.4is. They are using a machine that generates oxygen and hydrogen gas. They said once the gas comes in contact with carbon it burns it away from the front of the engine intake across the valves thru the cat and out the exhaust. The cops who were are waiting to get it done swore by it. I think they are working on getting the DC police car contract to do all those cars.
    All I can say is try it out....I'm taking out CTS to get done this weekend and will report back. Saw them do an old forerunner and when he finished it was running smooth as butter with 288k on the odometer.
    I think one of the members on the forum does this as a business in the UK and doing pretty good. I have asked him if it was like induction cleaning and he said no not the same.
    good to see some activity on the regional forum.
    May 20 2010
    That does sound like an interesting process. I'm still a bit skeptical, namely because the strong bonds carbon forms (which makes it so f'in difficult to clean). I'm not so sure how well or long it would take to burn those deposits off. Though I have read that black carbon can act as a catalyst, and pure O2 wants to react with nearly everything.
    On the traditional note, a couple years ago I went and had my 2.0T done both manually and chemically (i.e. BG) for $550. It was great afterwards! If this can replicate it, that sounds like an awesome deal!
    Veteran Member Four Rings Race Shooter's Avatar
    Dec 22 2006
    Raleigh
    If you google the process you'll see some info on it.
    The hydrogen/oxygen mixture is put in through the intake manifold, so it will flow over the valves, however, the majority of the cleaning is done IN the combustion chamber where the hydrogen and oxygen cause for a really hot burn to burn off the carbon deposits.
    It does say an intense steam is also generated that will flow through the exhaust and clean out turbos, cats, exhaust and will circulate through the EGR system, so some of it will come back into the intake manifold and soften up the carbon on the valves.
    They say you run the car for about 30-40 minutes while hooked up, so possibly enough will get back through the system to clean the valves to some extent, however, it will not be as good as a manual cleaning.
    It seems like it might be something good to do relatively often, before the valves get too caked with gunk because I dont see how it will do enough for a heavily carboned up intake system since just the flow of the hydrogen and oxygen over the valves will do nothing, its the burning and hot steam that do the cleaning.
    At least that is how I read the process when googling it.
    2014 Porsche Cayman S Guards Red
    2015 Sepang Blue S4 6MT Gone...easily forgotten.
    2004 Nogaro Blue S4 Avant 6MT Gone...but severly missed .
    Jim Sykes Photography motorsports photography
    Jun 07 2013
    D.C.
    My weekend started early so I have nothing better to do on this rainy day than google.
    I see this process is very popular in Asia and Europe. To me it seems like I am living in a GE scary idea commercial.
    Maybe in the US the average mechanic does not want to spend 8 to 10 grand for the equipment plus training.
    The mechanic I spoke to was a former military mechanic and saw the process in Asia done all the time on cars over there.
    From what he said they love cars horsepower and racing as much as we do.
    Kept searching and found this.
    https://www.facebook.com/F5ECC "this place is in the UK"
    and this
    https://www.facebook.com/DeCoke-Engi...9358968410933/ "this place is in Florida"
    Both places seem fairly new so ideas are taking off.
    So it seems the process is getting some traction well I am going to keep researching will report back as I find interesting things about this process.
    I love horsepower and a process that can give it back to me without taxing my bank account is exceptional.
    May 09 2013
    Loads of junk.
    Northern Virginia
    Quote Originally Posted by Gurltech View Post
    and this
    Cuppa on a5oc is the one who is doing it in the UK. not sure if that is the same one you have on your facebook link.
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by Race Shooter View Post
    That is what shops would recommend for the BG Induction service. Ideally it will clean the soft mushy carbon deposits but the caked on stuff will still be there.
    Replacing your PCV valve every 30K miles would be a lot more beneficial in my opinion because the wet gooey oil wouldn't be getting on the intake valves so the buildup wouldn't grow that fast. Same idea as a catch can but neither is going to totally solve the issue so manual cleanings still will be required every so often depending on how much performance the owner wants on a regular basis.
    Jun 30 2009
    Washington DC
    Oh cool, so that is why all the cars were there.
    I drive down that road to go home occasionally, but never stopped anywhere on Bladensburg north of benning road. This is good to know. please report back your results if you did go out to do it yesterday or today.
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Isn't this basically the good old fashioned Italian tune up?
    /// 2012 S4
    RocEuro Intake | AWE/GIAC Stage 2 | 19" Titanium Rotor Wheels 10mm H&R spacers | RS5 BBK & ECS 2pc front/rear wave rotors | Renn RS-51 19x8.5 20.5lbs | JHM LW/HD Pulley | MMI 3G+ rev. G and controls retrofit | vagcom stuff | Jokerz ported coated supercharger | KW V1
    Mid-Atlantic Forum (MD/DC/VA)
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    For Induktion's price I'd go there in a heartbeat.
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    May 10 2010
    Charleston, SC
    Quote Originally Posted by audistealth View Post
    Seems like it. Which in the case of a DI engine, would actually probably make the problem worse.
    Dec 13 2019
    Virginia
    Smile
    Wondering if you know the name of this place?
    I'm in the DC area too and looking for affordable carbon cleaning.
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    If there is such a thing as "affordable carbon cleaning", I would stay away from it. At best, it would do nothing.
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    Quote Originally Posted by Serpent View Post
    I vote second on this.
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
