Results 1 to 7 of 7
    Jul 03 2013
    new hampshire
    Temp gauge and stumbling issue ?
    Ok so I drove my car to town this morning to drop my son off at school apon arriving home the car started to stumble and the temp gauge went from the half mark to cold, also noticed while this was happening that the cooling fans for the radiator were on full blast. I scanned the car for codes and only got one for the 02 sensor reading rich. Can't imagine that would cause issues with my temp gauge. Any ideas fellas thanks
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by b00sted04 View Post
    You need to replace your thermostat. It's stuck open
    Jul 03 2013
    new hampshire
    Brand new as of a week ago but I guess it could be a bad one. I was wondering if maybe the temp sensor was going bad that if I'm not mistaken controls the temp gauge correct
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Glad my thermostat isn't doing this. Been stuck for a little while now, changing it this weekend though.
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    The fans will come on full blast whenever there is a coolant system malfunction or similar fault code. The temp sensor in the coolant flange on the back of the cylinder head is where the gauge gets its reading from. Could be a faulty sensor but could also be a faulty thermostat. I had one fail on me within a week a while back. It was a cheap no name brand one. I would recommend only using OEM or at least OEM supplier for the b6 and b7 thermostats.
    Nov 02 2013
    Alberta Canada
    Definitely thermostat. Like about poster said oem ftw.
    Jul 03 2013
    new hampshire
    Fixed it, it was not the thermostat also when I replaced my thermostat it was with a oem unit. Turned out to be the coolant temp sensor, replaced it and everything is good.
