Results 1 to 9 of 9
    Nov 17 2015
    350z
    Boston
    Question about CV boot grease
    My inner CV boot came off on one end, the shop said it was "cracked" but I do not see any damage. I am going to put it back on with a new clamp. Is this part of the boot supposed to be filled with grease? If so, how full?
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    You might as well disassemble it fully, clean and inspect the balls/housing surfaces. You might want to get a new seal and pack of grease.
    Nov 17 2015
    350z
    Boston
    I have some grease just not sure how much is supposed to be out into that side of the boot ?
    Aug 09 2012
    2013 S4 phantom pearl
    IL
    he's saying since it's opened up, disassemble the CV joint, clean the cage, inner part of joint, bearings, repack with your new grease, and use a new single-time use clamp to close it up. makes sense since it's already open. may reveal something ie the reason the boot opened up. could fail again if there's an impending issue that isn't addressed. there's a few DIY guide on this. pretty straight forward process that takes 15-20 minutes.
    Jul 04 2012
    Woodbridge, VA
    Holy fuck man how many posts are you going to make regarding this axle of yours?
    Aug 09 2012
    IL
    Quote Originally Posted by vavJETTAw36 View Post
    wait is this the same one that was posted as it was ON the car and the boot twisted off? I think someone suggested the retaining clip popped off. just rebuild the damn thing
    Nov 17 2015
    350z
    Boston
    No this is not the same axle, this is the OEM one that the shop told me was ripped, then I replaced it without inspecting it with an Empi that popped a day later. Now I'm going back to the OEM, I am rebuilding it as you guys recommend just want to know if the boot needs to be completely filled with grease.
    Apr 20 2005
    New Hartford, IA
    Ok, clean it first and look at some of the packages they supply in CV boot kits to get an idea of just how much grease to use. Not super critical, but don't pack it full, make sure some is on both sides so nothing runs dry at first.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Jul 04 2012
    Woodbridge, VA
    If you don't have Bentley or something similar, I suggest getting one. It tells you the amount of grease along with capacities of a bajilion things.
