Before all this i replace the crank sensor to rule that out. Any idea why i dont get spark? Checked all the fuses and they are good.
Code:
Thursday,07,January,2016,12:22:05:50717 VCDS Version: Release 15.7.3 Running on Windows XP x86 www.Ross-Tech.com Address 01: Engine Labels: 06B-909-518-AMB.lbl Control Module Part Number: 8E0 909 518 BC HW: 8E0 909 018 A Component and/or Version: 1.8L R4/5VT G 0003 Software Coding: 0016711 Work Shop Code: WSC 88641 551 633322 VCID: 72E014956E693CAE77-513C 10 Faults Found: 17633 - Fuel Injector for Cylinder 1 (N30) P1225 - 002 - Short to Ground 17635 - Fuel Injector for Cylinder 3 (N32) P1227 - 002 - Short to Ground 17636 - Fuel Injector for Cylinder 4 (N33) P1228 - 002 - Short to Ground 17634 - Fuel Injector for Cylinder 2 (N31) P1226 - 002 - Short to Ground 17833 - EVAP Purge Valve (N80) P1425 - 002 - Short to Ground 17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2 P1117 - 002 - Short to Ground 17843 - Secondary Air Pump Relay (J299) P1435 - 002 - Short to Ground 17829 - Secondary Air Injection Solenoid Valve (N112) P1421 - 002 - Short to Ground 17697 - Boost Pressure Control Valve (N249) P1289 - 002 - Short to Ground 17522 - Oxygen (Lambda) Sensor; B1 S2 P1114 - 002 - Internal Resistance too High Readiness: 0110 1100 VCDS Version: Release 15.7.3 Running on Windows XP x86 Data version: 20151216 www.Ross-Tech.com Thursday,07,January,2016,12:33:52:50717 Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAULC68E25A121795 Mileage: 167620km-104154miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06B-909-518-AMB.lbl Part No SW: 8E0 909 518 BC HW: 8E0 909 018 A Component: 1.8L R4/5VT G 0003 Coding: 0016711 Shop #: WSC 88641 551 633322 VCID: 72E014956E693CAE77-513C No fault code found. Readiness: 0110 1100 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 A Component: ABS/ESP allrad 4529 Coding: 04275 Shop #: WSC 06435 VCID: 264838C5C221100E2B-5120 2 Faults Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 35-00 - - 18258 - Powertrain Data Bus P1850 - 35-00 - Missing Message from ECU ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AD Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 06335 VCID: 63CE61D1F193A5260C-513C 5 Faults Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 00532 - Supply Voltage B+ 52-10 - Supply Voltage Too High - Intermittent 00532 - Supply Voltage B+ 53-10 - Supply Voltage Too Low - Intermittent 01206 - Signal for Duration of Ignition Off Time 27-00 - Implausible Signal 01336 - Company Data Bus for Comfort System 80-00 - Single-Wire Operation ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 F Component: int. Lastmodul KAN 0517 Coding: 01014 Shop #: WSC 06335 VCID: 356AEF890F876B9692-4B00 3 Faults Found: 02105 - Supply Voltage for Light Detection Sensor 57-00 - Electric Circuit Failure 02104 - Light Detection Sensor (G399) 30-10 - Open or Short to Plus - Intermittent 01312 - Powertrain Data Bus 79-10 - Please Check Fault Codes - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 K Component: Airbag 8.4EP 1001 Coding: 0010607 Shop #: WSC 06335 000 00000 VCID: 3F868DA16DBBA1C648-513C 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 N Component: Lenksáulenmodul 0611 Coding: 01041 Shop #: WSC 06335 VCID: 3E78F0A53AB1A8CE43-4B00 1 Fault Found: 00532 - Supply Voltage B+ 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 900 N Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 01331 Shop #: WSC 94753 VCID: 2F66DDE1EDDB5146D8-515A WAULC68E25A121795 AUZ6Z0D0348851 4 Faults Found: 00562 - Sensor for Oil Level/Temperature (G266) 27-00 - Implausible Signal 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent 01314 - Engine Control Module 49-10 - No Communications - Intermittent 01316 - ABS Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BB Component: Komfortgerát T7B 1612 Coding: 11880 Shop #: WSC 06335 VCID: 72E014953E693CAE77-4B18 Subsystem 1 - Part No: 8E1959801 Component: Tőrsteuer.FS BRM 0205 Subsystem 2 - Part No: 8E1959802E Component: Tőrsteuer.BF BRM 0205 Subsystem 3 - Part No: 8E0959801A Component: Tőrsteuer.HL BRM 0205 Subsystem 4 - Part No: 8E0959802A Component: Tőrsteuer.HR BRM 0205 14 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 53-10 - Supply Voltage Too Low - Intermittent 00962 - Alarm via. Tilt Sensor 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01573 - Alarm triggered by Door Contact Switch; Rear Left 35-00 - - 00932 - Electric Window Motor; Drivers Side (V147) 62-10 - No or Incorrect Adjustment - Intermittent 01705 - Selection Switch for Mirror-Adjust (E48) 27-10 - Implausible Signal - Intermittent 01331 - Door Control Module; Driver Side (J386) 52-10 - Supply Voltage Too High - Intermittent 01332 - Door Control Module; Passenger Side (J387) 53-10 - Supply Voltage Too Low - Intermittent 01333 - Door Control Module; Rear Left (J388) 52-10 - Supply Voltage Too High - Intermittent 01562 - Rear right door 59-10 - Can't Unlock - Intermittent 01334 - Door Control Module; Rear Right (J389) 53-10 - Supply Voltage Too Low - Intermittent End-------------------------(Elapsed Time: 06:23)--------------------------
Cleared those codes and nothing came back after i tried cranking.
