Results 1 to 12 of 12
    Aug 28 2015
    Middletown, DE
    Is the stage 2 APR upgrade worth it
    To be clear, i don't know shit about this stuff. I have a 2012 S4 MT. I did the APR Stage 1 ECU chip when i bought it a few months ago. Is it worth doing the Stage 2 , what is difference between Stage 2 and i've seen Stage 2 +?
    Thanks.
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    There is no stage 2+ in apr.
    Value is up to you. Wow factor from stock to stage 1 is way more than 1 to 2
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Nope, If you search you'll quickly see its just not worth it.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    Stage 2 is the Pulley and Tune upgrade,2+ is generally if u get the intake + SC cooling as well
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Quote Originally Posted by GRUMPY-S4 View Post
    They are the ones that called it Stage 2+ and later dropped the "+". In the end though, no difference (pulley and tune).
    As for OP and "is it worth it"? Only you can answer that. More torque is worth it to me and I haven't heard of anyone that regretted going from 1 to 2.
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    Yes, it's worth it. There's a million threads on Stage 2 with many, many, MANY satisfied drivers. Also consider the APR TCU tune with the Stage 2 ECU. Both combined make a dramatic difference in how this car performs.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by justr0 View Post
    No.
    See below.
    Quote Originally Posted by Silverbullet S4 View Post
    Very well stated on all points.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    Yes, Stage 2 wakes up the mid rpm range where you will really appreciate the added torque.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    Yes. It's worth it. Period.
    Established Member Two Rings Turboaudi01's Avatar
    Aug 14 2015
    '13 2.0T GLI Autobahn w/Navi 6mt STG II - -- -01 1.8T A4 5mt
    Central Ct.
    YES YES YES 110% Actually it's not enough
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    🔹🔷15 Sepang S4🔷🔹〰6mt〰Black Nappa〰Carbon Atlas〰Sport Diff〰Tech Pack〰SC Badges〰B&O〰VMR 710's 35et 255/30/zr20 Sumitomo〰H&R Sport Springs〰Full Resonated Miltek/100mm〰CTS Turbo Intake〰CTS Turbo Pulley〰Custom EPL Tune〰
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    Just picked my car up from getting stage 2 done, and it increases the smile factor.
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Nope, don't do it. Just read all the reviews and identical threads and you'll see...
