Results 1 to 8 of 8
    Nov 17 2015
    350z
    Boston
    Is this OEM axle still good?
    Can someone tell me what needs to be done to reuse this axle? The outer boot is fine, but the inside is disconnected or ripped?
    http://s8.postimg.org/qix76fbat/image.jpg
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    You are going to need to check the play on it and check the internal parts for any damage. Can't tell by just looking at a ripped boot.
    Nov 17 2015
    350z
    Boston
    Is the inner boot easy to replace and can it be bought separately?
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    Quote Originally Posted by j753k View Post
    https://www.ecstuning.com/Audi-B5_S4...nner/ES357806/
    Feb 18 2013
    Louisville
    If it's not making any noise I would just clean it up, grease and reboot it.
    Nov 17 2015
    350z
    Boston
    It seems like the boot just came off? Im not sure why the shop told me it was torn.. I do not see any tears.. Maybe it just needs a new clamp to hold it on tighter??
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    Stock inner boot is pre-assembled to the metal flange with a press-on ring & not a clamp. You could probably get away with re-clamping it but not for very long.
    Get an inner CV boot kit, then clean & regrease the inner joint before you replace the boot. Inners are way easier to service than the outers, just need to pull a snap ring.
    Get the boot kit from GKN and save yourself some money.
    May 16 2008
    South Texas
    Genuine axles are serviceable unless the axle itself is bent or otherwise damaged.
