Results 1 to 7 of 7
Thread: Hood Sensor
    Jan 04 2016
    Charleston, SC
    Hood Sensor
    I tried searching through the forum, but only found one sort of relevant thread.
    My hood sensor keeps pinging that the hood is open even though it is clearly secured. I think I can see where the sensor is, but it looks like it is connected properly.
    Is it possible that my sensor is just broken completely?
    I read on a different forum that the hood switch is connected to the vehicle wiring harness with a 4 pin connector (connector T4) the "power supply for the anti-theft siren runs through the connector to the hood switch. The anti-theft siren has its own little battery inside it, which means it will work (for a while, anyway) if the connector has been disconnected. You might want to check and see if the anti-theft siren on your car works or not. If it does not work, this suggests that the connector T4 might be disconnected."
    Is it possible that this sensor being broken is why locking the car and my alarm system do not make any noise, and instead just flash the cars lights? I had just assumed my battery for the alarm was dead.
    Thanks for any help!
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Sounds like its broken.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 04 2014
    2009 Gray A3
    California
    The switch is a normally open contact. If you disconnect the switch from the wiring loom, the car will thin the hood is closed.
    Only issue is when the oil level light comes on as the hood needs to show open to reset the oil level.
    Sent from my SM-G920F using Tapatalk
    Mar 05 2012
    11 Q5 2.0T, 18 Q7 3.0T, 89 Foxbody!
    Bucks County, PA
    Quote Originally Posted by DarrenOman View Post
    Even on a B7?
    2012 Q5 and 2018 Q7
    Nov 04 2014
    2009 Gray A3
    California
    That, I am not sure about. I cant imagine they would have changed it from B6 to B7, but someone else will need to answer this, or just unplug the connector and try it. Connector is on the left side between the center of the Rad and headlight, near to the edge of the rad.
    Oct 25 2014
    2006 A4 Avant 2.0T, 1983 Volvo 242 turbo
    South Portland, Maine
    I just fixed this problem in by B7 A4. It was only intermittent, but usually when it rained which was a clue that it was an electrical gremlin. Not only was the hood open warning light on, but I couldn't lock the car because it would also trigger the alarm (as you mentioned, just the lights but no noise). I took a picture of my old one. You can just barely see the green corrosion right where the wires come out of the sensor.
    It's an easy swap and fixed the problem.
    Nov 05 2015
    Westchester NY
    Thread bump...
    Im having the same issue -- how difficult is it to swap hood latches?
    Any tricks or suggested tools for disconnecting/reconnecting the cable?
