Originally Posted by
mmobed
Well I seem to have figured it out in case anyone else runs into this issue. It seems as though the MMI on my 2013 S4 did not consider the SD cards root directory as a its own directory so you were able to put all your songs up to the max medium limit with no issue. Now on the 2016 A6 the root directory counts against the directory max (1,000) and not the medium max (10,000). I had 2200 songs to be precise so when they were all on the root directory of the SD card it only saw up to 1,000 of the songs hence 1200 the missing songs. By splitting them into 3 folders it now recognizes all my songs. Kind of odd that they went in this direction since it was much more convenient that I was able to have all 2200 songs on the root directory of the SD card and my S4 read every single one fine but I'm glad I figured it out and have all my music back. Hope this helps!
Hello and thank you for your message. This was exactly my problem as well in my 2018 Q5 with the SD card. Placing my MP3 files in individual artist folders on the card (about 3900 songs) - that worked fine. MMI could see all the folders and songs, but cannot do a 'global shuffle' on ALL songs this way. Putting all the songs in one folder also does not work - MMI only reads 1016 songs (but you can now shuffle all those songs). Putting all the songs on the root of the SD card also does not work, only 1016 songs read. But...like you mentioned ...creatiing 3 folders on the card and placing about 1300 songs per folder - that works perfectly. ALL songs are recognized and I can at least shuffle per folder now. Thanks again, this is a good workaround.
I had a 2010 Q5 previously and there was a limitation on max folders/songs on SD card but at least you could shuffle ALL the songs on the card with hundreds of folders created.
