Results 1 to 23 of 23
    Jan 06 2016
    Chino Hills
    Flat Bottom Steering Wheel 2005 and up..(Auto) RS6 with S-Line Badge
    Listed in the A6 Classifieds. RS6 Flat bottom steering wheel and airbag (Auto) $1000 or OBO..Questions, please call or email..714-872-1788 [email protected]
    http://www.ebay.com/itm/231827028760...84.m1555.l2649
    Jan 06 2016
    Chino Hills
    Bump...Still Available
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    Wish they are more affordable :)
    Veteran Member Four Rings Axel-'s Avatar
    Jan 29 2011
    2006 JHM Stg 1 SC'd S4 Avant 6MT
    Toronto, CA
    Seems like a decent price. I have the TT-RS which is nearly identical (perforated leather all around instead of the just the sides). Fantastic mod. You're constantly using the steering wheel when driving so you get a lot of good use out of it :)
    Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq - Review of all my mods
    JHM Stage 1 SC - JHM IM - JHM 5R clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - JHM shifter - Trexturk DP - Magnaflow CB - Hotchkis RSB - JHM IS - 034 Adj. FUCA - STE Gauges
    Jan 06 2016
    Chino Hills
    Make me an offer...
    Jan 06 2016
    Chino Hills
    Quote Originally Posted by Rthiess1 View Post
    Make me an offer...
    Bump...Taking Offers..
    Deactivated One Ring
    Jan 21 2016
    San Francisco, CA
    I have a 2005 S4 (b6) without Audio controls on the steering wheel.
    Can I install this wheel in my car, does it fit?
    And if it fits, is it possible to hook up the Audio controls?
    Jan 06 2016
    Chino Hills
    Quote Originally Posted by PhatBaja View Post
    PhatBaja, these are questions that I do not know, however, I would try a search here on Audizine and if you still come up blank, give a call to Europrice and ask, they should know.
    Jan 06 2016
    Chino Hills
    Bump..Make an offer
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    That's a nice wheel..If the cdn dollar wasn't so bad right now I would have taken it
    Jan 06 2016
    Chino Hills
    Make me an offer S4 Matty....
    Jan 06 2016
    Chino Hills
    What no one is interested in this??
    Nov 13 2011
    b7 s4 avant
    It's not a bad deal, and the wheel looks great. It's just that unless the harness has been re-wired, it isn't plug and play for a B7. Good luck though!
    I drive a truck now.
    Oct 03 2015
    West Hartford, CT
    is the rewiring a pita? when you take off the existing wheel can you use that harness?
    2015 Monsoon Grey S3
    2008 Brilliant Red S4 Avant 6MT @thatredwagon
    Established Member Two Rings kidzero's Avatar
    Jun 28 2004
    Porsche Cayenne Turbo, Porsche Boxster
    I also would like to know about the wiring harness.
    Nov 13 2011
    b7 s4 avant
    Quote Originally Posted by verymickey View Post
    You can use the existing harness. You just have to relocate a couple of the wires to different pins I believe. There is a thread buried somewhere here in Audizine that explains it. I bought my airbag already wired from Europrice so I haven't done it myself
    Jan 06 2016
    Chino Hills
    Thanks geebus, the wheel is very nice and a great mod. It comes with two harnesses, one of them should be a plug and play, never tried it!
    Jan 06 2016
    Chino Hills
    Below are the directions, found in a search on Audizine, for the TT's harness. If anyone is interested in doing a rewire, this should be the same. I will post the harness numbers for the two that I have.
    "OK, here's the procedure to rewire the harness for the TT MKII MFSW. The harness has part # 8J0 971 589 B.
    MAKE SURE TO DISCONNECT THE BATTERY BEFORE DOING ANY WORK WITH THE AIRBAG!
    The 12 pin plug connector (yellow) on the TT MKII harness needs to have three of its wires re-assigned. Open the cover on the back of the harness plug. Looking at the plug connector from behind as if you were going to plug it in, there are 2 rows of slots, which we will number
    1-2-3-4-5-6
    7-8-9-10-11-12
    3 through 6 are for the airbag - DO NOT TOUCH!
    7 = Brown
    8 = Yellow (horn)
    9 = Purple
    10 = Red
    1, 2, 11, 12 are empty.
    Push out the purple lock in the harness and then release the appropriate wire to be re-assigned.
    You need to move the following wires:
    move the Brown wire from 7 >to> 1
    move the Yellow wire from 8 >to> 2
    move the Red wire from 10 >to> 8
    All MFSW controls including the horn should now work. You may also need to trim the tabs from the sides of the plug to be able to insert into the S/C ring socket. You'll know what I mean when you see it.
    Good luck!"
    Jan 06 2016
    Chino Hills
    Bumpity Bump..Bump, still available..
    Dec 19 2014
    Salt Lake City
    Quick question, How come you're selling? I'm considering, pending a couple bike-related purchases ; )
    Jan 06 2016
    Chino Hills
    Sold my A6 back in 2010, this has been sitting in the closet in bubble wrap, never installed and the Rotora BBK is sitting in plastic in my garage as well, spring cleaning in Winter a few years late..Give me a call if interested..714-872-1788
    Jan 06 2016
    Chino Hills
    Bump....
    Jan 06 2016
    Chino Hills
    SOLD
