Results 1 to 22 of 22
    Sep 02 2015
    Edmonton
    I Know This Sounds Crazy..
    Is there any way to retrofit the sound actuator behind the firewall to my B8? Tried searching but no one seems have done this.
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    Whyyyyyyy! Like really, why would u do that to yourself? LoL
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Finally someone likes me that actually find the Sound Actuator cool!
    Its a blast to hear people on the bluetooth say "you are in your car right" lol
    May 20 2012
    Chicago, IL
    I have a 2013 S5. Where is the sound actuator and how do I kill it? Do I seriously have one?
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Jan 28 2013
    Quote Originally Posted by mehware View Post
    You should have one. Look at your manual, specifically, the fuse section. One of the fuses on the drivers-side fuse bank is for the Soundakator (sp). Identify fuse. Pull Fuse. Done.
    May 20 2012
    Chicago, IL
    My lady says my car is too loud. First the diesel scandal now this.. #maritalproblems. Thanks obama...
    Sep 02 2015
    Edmonton
    I had a MK6 GTI that has it and I miss that little drama from time to time, you know, like MSG in your food once in a while...
    Jul 24 2015
    Quote Originally Posted by Lamprey View Post
    +1 it'll say "Soundaktor" or "Sound Actuator" in the manual. Probably Bank A fuse #5 on the driver side fuse panel (check your manual for exact fuse)
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    you can turn off the artificial sound by pulling out fuse#5 in drivers side first fuse bank. However some say if go to MMI you can turn down the sound and it is quieter than pulling fuse. When I first bought the car, the phony sound bugged me. I made the change through the MMI and now notice only real exhaust sounds coming from the exhaust system. It no longer bugs me.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Aug 22 2014
    bloomfield,ct
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by jygesq View Post
    The only adjustment within the MMI system that I know of for adjusting the Soundaktor volume is in the ADS menu, where you can adjust the setting to "Comfort" within the individual menu. I believe it would still be functional, but less than in Auto or Dynamic setting. I went in through VCDS and turned the volume all the way down which seemed to work. Obviously pulling a fuse is a lot less expensive than buying a genuine Vag-Com cable, though.
    SOLD 2015 Daytona Gray S4
    Dec 10 2012
    1983 Honda CB1000 Custom
    granville ohio
    I do not have mmi. It was cleaner for me to disable with vagcom. Pulling the fuse threw a code.
    Sep 02 2015
    Edmonton
    looks like everyone automatically jumps to "how to disable the sound actuator" when they see the key word, guys, I am asking how to install the damn thing lol
    Veteran Member Four Rings PitchS4's Avatar
    May 15 2007
    2021 SQ5 | 2019 Jeep GC Limited
    Northern VA
    Quote Originally Posted by ilovefood View Post
    The easy part is getting the part numbers from the B8.5 and wiring it into the fuse box. How it connects to the ECU to get throttle imputs would be more difficult to do unless someone has a B8.5 wire-harness diagram. You would need to recode the MMI as well IF the B8 MMI is even compatible. You might have to upgrade to the B8.5 MMI (it has been done on here).
    All in all probably more expensive then an exhaust.
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
    May 20 2012
    Chicago, IL
    I don't have ads on my s5. No "drive select" I hear pulling it may throw a code. Need a vag com. With the sound clapper disabled is it seriously quieter in the cabin?
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Oct 14 2012
    Empty...for now...
    SE PA
    ^ It's cheesy, but kind of impressive how that works.
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by SteveYem View Post
    Agree. Would be a fun device for gags.
    Jan 28 2013
    Quote Originally Posted by blbroo View Post
    Could be funny and I would throw down $20 for a goof. But, too bad it's not cheaper.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Sound-a-faker
    Biggest joke... so sad that motoring has come to that and that people dig it. It's an embarrassment is what it is.
    Veteran Member Three Rings Tweakophyte's Avatar
    Feb 15 2012
    Boulder, CO
    I know you're asking about the soundaktor, but have you considered an exhaust?
    MY12 Ibis, Titanium, 6MT, Sport Diff, Leather, Prestige : 35% tint, AK, SC Badges... CPO (kind of a mod)
    RSNav (S4), CR15
    Feb 01 2015
    20ae GTI 1.8BT, CBR F4i, Speed Triple R
    Lancaster, PA
    I did not have this experience.
    I kind of liked it, too. But I pulled it before i had my exhaust installed after trying all the settings through the MMI and there is def still sound coming from it on the lowest setting. When pulled, the car exhaust note was non-existent in the cabin with no music, windows down or up, even through full throttle runs, save for the exhaust fart.
    OP: I know this isn't what you are going for but your best option, and cheapest, might be to check the thread about various exhaust setups and find a very mild one with either a res or muffler delete or magnaflow replacement installed by a local muffler shop rather than trying to hack through all this and retrofit the soundacktor.
