Results 1 to 3 of 3
    Veteran Member Four Rings drjonez's Avatar
    Oct 27 2009
    2011 Q7 TDI Prestige, '72 Nova
    The Cheese State
    2003 Avant Part out - No Longer Available
    2003 Avant Part out
    Obviously I'm not asking $987654 for this....that's simply there to placate Panjo. Drop me a line with your needs!
    Well, it is game over for me. Had an engine fire a week ago, luckily I was able to put it out and keep it localized to the engine bay. The interior was untouched, most of the major stuff underhood was untouched as well. Tons of parts on the car and tons of parts on the shelf, drop me a line with your needs. I'll be pulling parts occasionally and posted in the varied for sale forums. Details:
    2003 A4 Avant, Bose + Cold Weather Package, 160k on the clock
    Engine/Performance
    1.8T, internally stock, compression/leak down tested 3 weeks ago in good shape, ATP catch can, EMUSA FMIC, powdercoated black cam cover, Fluidampr, ATP 3" MAF housing, APR Stage III+ software and injectors, Bailey DV, R8 ignition coils, GT2871R (56 trim (THE BIG ONE), .68 T25 turbine housing, 3" inlet compressor housing), T25 5 bolt outlet to 3" v-band, T25 log manifold, 034 Motorsports ignition coil adaptors, APR stealth exhaust
    Drivetrain
    TipTronic car swapped with the trans (0A3 6 speed)/diff from a 2005 S4, CM 850SS clutch, SS line, metal slave, JHM shift linkage, new front axles
    Suspension
    Eibach pro springs w/B5 front perches, S4 struts/shocks, AgencyPower heim front end links, 034 Motorsports heim rear end links, newer FCP front suspension arms with Powerflex urethane bushings, Hotchkis RS4 rear sway bar, H&R front sway bar
    Brakes
    1LE 4 piston front calipers (from Touareg/Cayenne) with nearly new S60R 330mm rotors and ThermoQuiet pads and SS lines, S4 rear brakes
    Exterior
    Polar White now Plastidipped Anthracite Grey, some rust starting, 25% tint all around, Panzer Plate,custom front wiper arms with common J hook attachment and newer Bosch Icons, votex hatch spoiler, Q5 wiper arm
    Interior
    Soul Black, Heated "Leather Seating Surfaces? seats (driver power, driver side has the common vinyl cracking on lower side bolster), DiNoc'd trim, S4 autodimming rearview mirror, hatch privacy cover, cargo net, S5 steering wheel/airbag/controls/computer (MFSW is fully functional), PODI dual (with no gauges), B7 center console, Symphony II+ w/aux in
    Wheels/Tires
    17" avant sport wheels w/Nitto NT01 R compounds, 5th spare wheel as well
    B5 Avus wheels
    pictured ASA wheels
    Other Misc. Stuff
    2005 S4 Sirius satellite tuner, wiring and antenna
    2005 S4 0A3 shift linkage
    2005 S4 rear suspension members, 54k on them
    2005 S4 rear sway bar + end links, 54k on them
    AEB air box
    AEB ignition coils
    AMB cam cover
    B6/B7 steering columns + trim
    Garrett GT turbo oil drain flange
    ATP Garrett GT turbo oil feed to stock feed adaptor
    NIB Stasis SS rear brake lines
    Parts sold:
    -B7 center console
    -front lower dash trim, glovebox and kick panels
    -console lid/arm rest
    -C pillar trim, hatch light
    -credit card tray
    -Q5 wiper arm
    -spacers and bolts
    -B7 keyfob
    -engine bay side cover
    -Symphony II+
    -034 Diff inserts
    -034 coil adaptors
    -Votex hatch spoiler
    -shift knob + boot
    -passenger foglight housing
    -hatch latch
    -headlight trays
    -R8 coils
    -GT2871R
    -T25 to v-band adaptor
    -T25 log manifold
    -oil level sensor
    -fuel rail
    -crossover coolant pipe
    -rear wiper motor
    -NIB Morimoto 4300k D1S bulbs
    -APR Stage III+ ECU and injectors
    -ATP billet MAF
    -7 06H ignition coils
    -PODI dual gauge pod
    -S5 steering wheel/MFSW parts
    -Hotchkis rear sway bar
    -H&R front sway bar
    -cruise control stalk
    -Fluidampr
    -front carrier
    -radiator
    -PS reservoir
    -hood strut
    -driver headlight
    List Date: 1/7/2016
    For more info, click here to view the original listing: 2003 Avant Part out
    This item is no longer available.
    Active Member One Ring boone91's Avatar
    Nov 19 2014
    1997 Volkswagen Jetta GLX
    Worthington, OH
    do you have the motor for the rear wiper?
    Oct 27 2009
    The Cheese State
    Quote Originally Posted by boone91 View Post
    No sir, I do not.
    '11 Q7 TDI Prestige
    Function > Form
