Results 1 to 18 of 18
Thread: 2009 A4 Build
    Established Member Two Rings yoshibishi's Avatar
    Jan 29 2015
    NC
    2009 A4 Build
    My cousin just picked up a 2009 A4 2.0T with 160k miles for $3,500 USD.
    The engine had jumped timing and bent the valves. Here are some pictures.
    2009 Audi A4 2.0T Build List
    Goal: 500 AWHP/500AWTQ reliable daily driver.
    Stage 1 - Initial Repair and Basic Tune
    • Cylinder head w/ valves, springs and cams and rockers from wrecked A4 with 30k - $1200
    • Repair/Replace OEM Pistons?
    • APR Stage 1 ECU - $600 (+70hp/+70tq)
    Stage 2 - Upgraded AWD Conversion
    • Audi S4 B8 Driveshaft - $800
    • Audi S4 Rear Axles - $300
    • Audi S4 Rear Differential - $800
    • Audi A4 Rear Subframe + Misc Mounts/Brackets - $200
    • Audi A4 Quattro Transmission - $700
    • Transmission Torque Converter Upgrade - $250
    • Audi A4 Quattro Fuel Tank - $250
    • ARP Stage 2 Exhaust - $1600 (free Stage 2 ECU Upgrade)
    Stage 3 - Brakes & Suspension
    • Drilled & Slotted Front/Rear Rotors - $300
    • HAWK HP Brake Pads - $200
    • H&R Coilovers - $1400
    Stage 4 - Engine Build
    • Ferrea Competition Valves - $450
    • Ferrea Valve Springs - $300
    • Ferrea Spring Seat Locators - $100
    • JE Forged Pistons - $600
    • ARP Forged Connecting Rods - $300
    • JE JG1004 3346 Piston Rings - $100
    • Mahle Connecting Rod Bearings - $30
    Stage 5 - Turbo Build
    • Still Researching...but most likely a K04 turbo with custom turbine for smooth and reliable power.
    Stage 1 Parts have been ordered and are trickling in.
    Thanks to EuroTech RTP in Raleigh for letting us use their shop space.
    2006 B7 S4 - Work in Progress
    2010 Evolution MR-Touring 340awhp/320awtq - http://imgur.com/a/eeIbp
    ETS Intake | ETS UICP | ETS V2 Quiet Exhaust | ETS HFC | Grimmspeed 3 Port | Seibon VR Front Lip | Rexpeed CF Hood Scoop, Side Skirts, Vortex Generators, and Lip Spoiler
    1992 3000GT VR4 450awhp/430awtq - http://imgur.com/a/dN2UG
    3sx Executioners (16T) | Dejon Intake | Dual Core FMIC | Turboback 3" Exhaust | 5Zigen FN01R-C | Too much to list..
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    I see you are gonna go with H&R coil overs I would recommend Vogtlands as they are less known but have a lot less documented issues and better adjustment. Also how many miles were on this car?
    Jan 29 2015
    NC
    Quote Originally Posted by bluetori View Post
    Thanks for the tip on Vogtlands, will check it out.
    The car had 160k miles.
    Jan 14 2010
    Georgia
    Quote Originally Posted by yoshibishi View Post
    Damn I missed that was there a service history?
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    500awtq/500awhp on a k04?
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Quote Originally Posted by poweredbyaudi7 View Post
    I thought the same thing.
    OP, you are going to have to look to another turbo if you want those power levels.
    Interested to follow the progress though! Shop is letting you use their space, but you guys are doing the work?
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    500 wtq on stock tranny and most likely an older 6 AT..
    500 awhp on a k04 variant
    Engine internals all sound good but I don't see you making past 400 awhp without going with something along the lines of a gtx3071 / efr6758
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    ^ This. And I'd strongly urge a 6MT with a performance clutch if you're going to be putting down that much power. I doubt the 6AT can take it.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    May 21 2015
    Nissan R32 GTR, Ducati 659
    Melbourne, Victoria, Australia
    Quote Originally Posted by Smellie View Post
    dont think youd even hit 450ish with a 6758.
    Apr 21 2015
    Quote Originally Posted by Shaph View Post
    Maybe with meth and an agressive maestro tune
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Interested to see how this will turn out. Anyone try to push the limits of the 6AT? Or OP, will you have a 8AT in there instead?
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    Jan 03 2013
    Baltimore
    I am interested in the upgraded driveline components. I thought the a and s drive lines were the same?
    Sent from my XT1096 using Tapatalk
    Mar 24 2014
    Quote Originally Posted by elscotto80 View Post
    The Quattro system may be the same, but the S4 "automatic" is a dual clutch not a traditional automatic.
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    [*]Transmission Torque Converter Upgrade - $250
    I'm interested in more information on this. Can you post/PM me details?
    My 2009 A4 Prem+ Build thread
    May 07 2014
    Great thread, in!
    I did not realize the driveline parts from the A4/S4 were different and interchangeable. So the A4 you got is a non-quattro model? Where are you sourcing the below parts, and do you need a rear subframe due to the Quattro conversion?
    2010 A4 2.0t quattro 6mt
    Veteran Member Four Rings bermudakid's Avatar
    Nov 02 2010
    Santa Barbara
    2011 A4 6MT - APR Stage II - Bang & Olufsen Aftermarket Sub - Eurocode HFC + Alu Kruez - 034 Trans Mount - S4 Brakes
    "Forget the "line" Get the real S"
    Instagram TPR.Visuals
    B6 Totalled - RIP
    Nov 16 2015
    omaha, ne
    i recently mis shifted a 09 a4 quattro. ended up spinning a rod bearing. going with je pistons integrated connecting rods acl calico coated race bearings for time being. limited budget but eventually gtx turbo, cts turbo is working on a gtx kit n should be out hopefully in 3 to 6 months at least thats what the rep was telling me
    May 21 2015
    Still doubt it. a 6758 maxs out at 490-500. im pretty sure we have more than 10% power loss
