View Poll Results: What to do.
Voters
16. You may not vote on this poll
  • 2.7tt swap
    6 37.50%
  • 2.8 repair
    10 62.50%
Results 1 to 20 of 20
    Active Member Two Rings Alexander_fogg's Avatar
    May 24 2015
    Audi 2.7tt quattro A6, Auid A4 2.8 Quattro (sold), Vw Bora 2.0 (Deceased)
    United Kingdom
    2.7tt swap or 2.8 repair.
    Hi,
    Got an oil leak on the left bank of my 2.8 V6, which i believe after changing the rocker cover gaskets, is the Cam Chain Tensioner.
    The little b*stards are about 20 quid, but unfortunately, require taking the whole top of the engine apart. unfortunately I dont have the space or knowledge for that so asked a couple garages. they all quote £500-£600. Shit.
    These are the little gaskets.
    So, as I have a niggle list of things I wanted to change in the future, I have considered swapping for a 2.7tt.
    Here's why, (Please dont say just buy an S4, as i got a very very good deal on my B5.5, it has top spec, low mileage and its already insured taxed tested ETC.)
    So on the niggle list.
    Slightly spongy clutch, it doesn't slip unless you change gear to drastically so wanted to change at some point.
    Always wanted more power an was considering supercharging, but the only kit is thousands, story for another day.
    slight hole in the down pipe that blows a bit. ( annoying )
    slight smell of fuel, i think from downpipe, or perished line.
    Either way i can solve all these with a engine swap to 2.7tt, with the bonus off added power.
    seeing as i was quoted £600 to repair to where it is, and i have a friends garage in newcastle that can put a 2.7tt into mine for £300 providing i bring all the parts.
    so, what are peoples thoughts ?
    Also does anyone have a detailed list of what it takes to put the 2.7TT from a C5 A6 Allroad into an A4 B5?
    Cheers
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    if you cant change the cam chain tensioner gasket on your own, how can you do a 2.7 swap?
    cars over they are pretty cheap (correct me if I am wrong). pick up an s4 that is wrecked and do the swap. Lots of guys would tell you just buy an s4, but they have gotten to the price where swapping isn't out of the question.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Nov 03 2011
    All Over!
    I will start by saying what you don't want to hear - buy an S4 instead.
    I personally don't believe in reinventing the wheel, which is EXACTLY what you'll be doing. It'll still be an A4 Quattro.
    I would go with an engine that was never an option in a B5.
    4.2 V8.
    VR6-T.
    I5 20VT.
    But hey, that's just me.
    1986 Type 85 Audi 90 quattro
    Nov 03 2011
    All Over!
    Wait - you got a good deal on your B5.5? Is there really such a beast? Even a B5 built in 2001 and registered in 2002 IS still a B5.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    We say this in the nicest way possible to save you headache and wallet abuse. Buy a real S4 and or repair what you have. The cost of swapping vs selling your old car and putting that to an S4 make it cheaper to change cars. If you are asking us advice on a Cam Chain Tensioner.... and then leading that to, I should just swap to a 2.7, well I fear for you. You don't know what you don't know and it will cost you. You can research and learn, which will lead you to the conclusion of sell car get S4. The B6 guys have done some 2.7 swaps. You will see there is a lot of work involved and little costs involved that add up fast.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Could be a 2001.5, but the only b5.5 I am aware of is a passat
    2000 S4- Working?
    Nov 03 2011
    All Over!
    Admittedly the B6 guys lean towards 2.7T swaps, because the 2.7T IS unique to the B6 platform. More work than if the swap was done in a B5 A4, but the rewards Vs the unreliable chain-driven S4 4.2 V8 (which is what the early swaps were aimed at) are worth the effort.
    With a B5, I would venture to say it's a pointless exercise, since B5 S4's can be had for as low as £1700 ($2500).
    Nov 03 2011
    All Over!
    Quote Originally Posted by redline380 View Post
    That's what I thought - a transition model before the arrival of the B6.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    But where's the fun in just buying an S? You of all people should support swapping any engine in! Also, wouldn't it cost less to insure over there?
    2000 S4- Working?
    Dec 10 2013
    Borden, Ontario, Canada
    I'm gonna pick up another B5 some day and make them both V8. The S4 will get a boosted V8 to keep with the heritage lol
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Senior Member Three Rings Arsenal2012's Avatar
    Aug 20 2015
    Chicago
    Damn son if u can get a complete engine swap for 300 why wont your friend do the cam seals for that price or lower?
    Its quite simple you set the engine at TDC then start pulling it apart and putting it together. I just did mine, would i want to do it alone, no.
    Like they said dont do 2.7 go with s4 if thats the case, you'll have to upgrade brakes and suspension get an ecu map and the price is going to keep going up and up.
    Before you know it you'll be like shit fuchk my life i should have bought an s4.
    Nov 03 2011
    All Over!
    It'll be fun to do the swap, for sure. But...
    ...to me, there'll be no sense of achievement, seeing as Audi have already paved the way with the S4.
    As for insurance, it'll cost a lot more to insure than a factory S4 B5 or B7.
    May 24 2015
    United Kingdom
    First thanks for all the response guys, ill try and get across my way of thinking more clearly =)
    My apologies, it may not be what they call a b5.5, but over here the B5 was made till 2000, then they made a "facelifted version and added traction control etc" which is what mine is,
    The guy that quoted for the engine swap was labour alone, as I was bringing him the parts.
    The repair was labour and parts, as the car also needs new cambelt water pump etc due to being taken off to get the cams out, when I priced up the parts myself, it was £300 in parts to repair mine as is then plus labour which was quoted at £200-£250, and at some point I would still need to update clutch etc as it is slightly on its way out.
    Some cars over here are cheap, S4's aren't one of them, as Nollywood says, you can get an S4 for £2000 ish, but over here that would be a much older one with very high miles, 200,000+. I know a lot of cars in america have that sort of mileage, but you guys do a lot of motorway miles and have nice weather =) Mine has only done 120,000, hence I really want to try and keep mine. To put the price into perspective, a good condition 2.8 2000 a4 would be £1700, with 110,000. S4s in that condition here are £5000 plus.
    Hope that makes sense.
    Not sure on the insurance, but I already have a policy, and it would cost me quite a lot to change to an S4, and I agree where is the fun hah =P
    Quote Originally Posted by Arsenal2012 View Post
    Yes he can quote lower for labour but the parts here where about £300, due to having new seals, rocker cover gaskets, cambelt, water pump etc. so would cost me £500 maybe even £450 to be no further than I am now.
    I really want more power and want to turn this car into a project that I am going to keep for a long time, with the end goal being an RS4 Limo style build.
    I have found several engines out of the C5 Allroad, for £400-£500, I would need to get all the little parts too, and I have priced up a new clutch too.
    Overall I have aimed for £600-700 in parts for the engine swap, meaning the overall swap would be between £900-£1000 Vs, £450-£600 so its double.
    but for that i would have an 2.7tt engine with 12 months warranty, new clutch, more power, about 300 BHP compared to 197 BHP at the moment, and also the added bonus of future modifications.
    Does this all make sense ?
    Hope so, Thank you all for your input just trying to figure out what to do thanks.
    Nov 03 2011
    All Over!
    Alex, I'm in the UK too, and know all the European B5's like I know my mama.
    I also have a last of the line B5 A4 2.8 Quattro Sport, with ESP as well. A minter, that cost me under £500.
    I can confidently tell you your guy charging you £300 for a 2.7T swap will soon realise it's a bigger job than he thinks. It's not difficult, more time consuming than anything else. How close to plug and play will depend on the age of the donor car. Even using a B5 S4 as the donor is not always straightforward. There are 3 different UK-spec B5 S4 engine harnesses, from 1998 - 2001 with different chassis plugs. Something your buddy needs to be aware of.
    I would be inclined to go with a V8 40V swap instead. At least you'll end up with a unique B5 - and with 4 B5 V8 swaps under my belt, and another almost completed, it's about the same amount of work as a 2.7T swap. Insurance will be similar for both, but at least you might as well go with something different for the privilege.
    Apr 22 2007
    Riverbank, Ca
    That gasket can be done with basic tools and the tensioner tool. You dont even need to loosen the cams.. I would just fix it, drive it for a while then sell it and grab an S4.
    IF your friend can put in a s4 engine for $300, then why not just have THEM do the tensioner seal?
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Jan 16 2006
    LA CA
    You should do the swap, just for our entertainment value. Please be sure to take lots of pics.
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    I would personally swap a N/A motor in. The 4.2 on a 2.8 trans would be a good setup and they sound mean as hell. I was into BAT 1.8t's but the headache of a turbo car isn't worth it. The 2.7 is twice the cost and more of a nightmare.
    For those who haven't heard or seen the B5.5 term, you need to get your head out of the sand. Venture into the B5 S4 and other platforms and become more knowledgeable.
    Again, I would go with a tuned 4.2 with exhaust on that 2.8 trans. GL
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    May 10 2015
    Pittsburgh PA
    I've always wondered why people don't commonly refer to the facelift cars as B5.5s, like the Passats or even the facelift B8s (B8.5s).
    In my opinion, you'll be much better off buying an S4. Sure the swap itself may be possible on the cheap, but by the time you get the rest of the car up to snuff (suspension, brakes etc.) You'll likely find yourself nearing the cost of an S4. Also, I'd imagine that you'd want to do some maintenance to your donor engine (timing belt, water pump etc.) before dropping it in which adds to the cost. If you want to make more power but don't want an S4, your best bet might be to look into an A4 1.8T Quattro. Lower cost of entry, and with a K04 turbo upgrade, performance close to that of an S4.
    S-Line converted | A7 356mm BBK | OEM 19x9" A8 wheels | Spec Stage 3+ Clutch | ECS LWFW | IE 3" downpipe | CTS catback | IEStage2+JB4 Stack Tuned | Meth Injection and more... +
    Oct 17 2009
    alonE, Pa
    ^ s4's can see 300 who on a really aggressive k03 tune. You would need a beefy tune on at least a 2871 Elim kit.
    Best to do a tuned 4.2. The power one makes will keep you side-by-side with a w/m stg 2 b5 s4 (300whp).
    STEVE
    Apr 02 2013
    above top secret
    I also own a b5.5 A4. Weird thing about it is the manufacturing/ registration was in 2003. I always have problems when specifying the car model coz people are always confused it with a b6. Additionally, the engine code is APU which is 90% similar to ATW in the US but has the AEB type 3 pin coil pack with ICM.
